Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 03-31-2004, 06:21 PM   #29
talmage
talmage's Avatar
Profile:
VERY interesting thread.
I have heard for years that the WD in WD-40 stands for 'Water Displacement.'
[Does anyone know what the '40' stands for?]
Guess that is why it works so well on wet wiring, distributer caps, etc.
One thing NOT to use it for is locks!
As posted earlier, it's petroleum base, does attract dust, dirt, etc., and might eventually gum up the pins, tumblers, etc.
EVERY master locksmith I have talked to recommends graphite powder for locks.
Be sure to 'work it in,' inserting and removing the key several times - and REMEMBER that there will probably be graphite residue on your key, so wipe it off before putting it back in your pocket.
talmage is offline   Reply With Quote
Old 03-31-2004, 06:23 PM   #30
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I have heard it was the 40th formulation that they tried. It worked so the name was assigned.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-31-2004, 06:38 PM   #31
talmage
talmage's Avatar
Profile:
Thanks for the info!
Reminds me about the 'lore' of the 10-15 onion.
Seems as though they plant them on the 15th of Octrober every year.
Then again, it might have something to do with the Texas A & M University Agricultural Research facility, where the onion was developed, in South Texas, being located on Texas Farm Road 1015!
Old 03-31-2004, 07:17 PM   #32
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
That is correct, Brett. Water Displacement Formula Number 40 wouldn't fit on the can...
Old 03-31-2004, 09:59 PM   #33
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Didn't know that!! I've used Wire-Dri (yellow can?) & WD-40 back in the 60's & 70's when dist. caps & ign. coils failed so often when wet!! I thought WD-40 was mainly designed as a penetraitng fluid for rusted fasteners & the wet ignition use was a bonus.
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 03-31-2004, 10:25 PM   #34
Andrew Selking
My Grandparents Airstream
Andrew Selking's Avatar
Profile:  2007 25' Safari FB SE
Fort Worth , Texas
WD-40 is good for one thing in Texas. That is starting a diesel engine when it is cold out.
Use it two or three times a year in January.
It will lock up any moving parts in a day or two. It is not a lubricat in dusty conditions but starts diesel real well.
Andrew Selking
WBCCI # 6062 VAC
Andrew Selking is offline   Reply With Quote
Old 04-01-2004, 02:50 AM   #35
jjonesnc
jjonesnc's Avatar
Profile:  Cary , North Carolina
Images: 8
The product began from a search for a rust preventative solvent and de-greaser to protect missile parts. WD-40 was created in 1953 by three technicians at the San Diego Rocket Chemical Company. It's name comes from the project that was to find a "water displacement" compound. They were
successful with the fortieth formulation, thus WD-40.
jjonesnc is offline   Reply With Quote
Old 05-07-2004, 11:53 AM   #36
Penguin
Penguin's Avatar
Profile:
what about WD-40 running down the skin?
The rock guard on my front window is frozen so tightly that it feels like it's welded. I was gonna spray WD-40 but thought I would read in here first, because I don't want to do any MORE damage to my Trade Wind's skin.
After reading this thread, I THINK I can safely spray it on the latches, of course I will mop up what runs down the front!
Any input? OK to spray it on the latches of the rock guard?
Connie
Penguin is offline   Reply With Quote
Old 05-07-2004, 03:29 PM   #37
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Having never tasted WD-40 I wasn't aware of its tract qualities but should I use it on the door latch of my trailer? It doesn't stick all that well so I was thinking of using white grease--just a little. My door latch sticks.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 05-08-2004, 05:14 AM   #38
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Cool You don't say...
Originally Posted by tinman7
My wife said if she had known of wd 40 before we were hitched, she wouldn't have needed me!
This begs a response~!!
I'm not gonna~
ciao
53FC
AIR 807
53flyingcloud is offline   Reply With Quote
Old 05-08-2004, 06:54 AM   #39
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Originally Posted by argosy20
John, have you ever tried Howe's oil? It seems to be real good stuff. While not as reportedly universal as WD 40, it is very good as a penetrating oil, and doesn't dry.
never heard of it terry!
john
you call them ferrets, i call them weasels.
Old 05-08-2004, 07:44 AM   #40
overlander63
Rivet Masher
L.A. , California
john
http://www.howeslube.com/products/index.php/category/40
Try this link.
Old 06-15-2004, 06:48 PM   #41
JOHN L
JOHN L's Avatar
Profile:  I currently do not own an Airstream
LASALLE
Another use for WD-40
My wife and I purchased an Argosy Minuet 6.0 wich had peeling decal striping around the entire periphery! The WD-40 removed all the glue residue without harmimg the painted surface! It worked better than anything else I tried, and made a big job a lot smaller!
JOHN L is offline   Reply With Quote
Old 06-15-2004, 07:34 PM   #42
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
John,
be sure to search the forums for the dangers of WD 40. Being a machinist (I read your profile!) you probably already know about material safety, so 'nuf said!.
Since you're in Windsor, you ought to come to the Mackinaw City rally next month. We're new to Airstream ownership and the forum, too, so you know that there will be other newbies there too!.
John
AYRSTRM2 is offline   Reply With Quote
