Old 02-25-2016, 09:27 PM   #21
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I would have to call "bs" on that offer.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 02-25-2016, 10:17 PM   #22
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Woah -- crazy expensive.
For the past 10 years we've been waxing once or twice a year and it has kept the finish perfect. We use a good paste wax.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 02-25-2016, 10:49 PM   #23
mpsgolf's Avatar
2015 28' International
Ofallon , Missouri
I agree with others, way too much money!!
The aluminum does come with a corrosive on protective coating but it is not perfect and some normal care is important. Surface (filiform) corrosion is not uncommon on AS.
You should wash regularly and wax approx 2x per year. I use Walbernize since AS recommends it. It is easy to apply and does leave the outside looking clean and shiny. I actually enjoy doing it and it is one way I give the trailer an overall thorough inspection for problems.
IMHO save your money, buy some Walbernize or other good wax made for the purpose, use a bit of elbow grease and enjoy the outdoors! A little Kentucky bourbon can be enjoyed whilst waxing on a beautiful day too!!
mpsgolf is offline   Reply With Quote
Old 02-27-2016, 06:07 PM   #24
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Even considering that we may be talking $80 per linear foot, that's $2000 to wax your trailer. Sounds like somebody has included the "couple months behind on the child support" correction factor to that pricing. That's more like the polishing price than a waxing price.
Old 02-27-2016, 06:49 PM   #25
Goal15's Avatar
Holly Lake Ranch , Texas
Turtle wax ice. Goes on really easy. Took about 2 hours by hand on my 23
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 02-29-2016, 10:03 AM   #26
2006 25' Classic
atascadero , California
contain filiform
Just bought a 2006 Classic, and it is in very fine shape except for a few, very small areas of filiform around a couple of handles, etc. My question is if this is an eventual death spiral of the stuff or if it can be contained without spreading. Any thoughts appreciated.
Hope this was not reposted more than once!
robgf1 is offline   Reply With Quote
Old 02-29-2016, 10:36 AM   #27
1986 31' Sovereign
Miami , Florida
Filiform is more of a cosmetic issue than structural. If you use Corrosion X or Boeshield on the areas semi-annually that should stop the spread.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 02-29-2016, 05:54 PM   #28
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
SO would you apply or spray the corrosion x on the area first, wipe it off or let it dry? and then wax over it? not sure how that works.
Mike
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 03-06-2016, 09:46 PM   #29
2015 27' Flying Cloud
Irrigon , Oregon
Good information
Alluminati: not all conspires are theory,Alluminati is a 2015 27fb Flying cloud😎
Tv: 2015 Gmc sierra 3500 duramax allison 😇
"We like it"
FunyFarm is offline   Reply With Quote
Old 03-07-2016, 08:33 AM   #30
1986 31' Sovereign
Miami , Florida
You only need to apply corrosion preventative where water could potentially seep between the aluminum and the factory applied plastic coating. So, window cut-outs, vents and the like. Google "corrosion X on Airstreams" or something similar and it should bring up several threads on the subject.
Mike
Young, lovely bride
Old 06-04-2016, 10:51 AM   #31
Boxite's Avatar
2008 22' Sport
Just reading thru threads and discovered this one and thought I'd pontificate on my own experiences with riveted aluminum structures...
My background in aircraft mx, and as a former attendee at Toyota Tech school (waaay-back) "larned" me a few things about this..
Firstly (and no criticism of Spelunkus who reminded me of such matters) ....when one calls "Airstream" or "Boeing" or "younameit".... one usually gets the person who simply answers the phone and passes along the general opinion of those that stand around that persons coffeepot.
Unless one talks directly with a technician or engineer-type who is a "SME" (subject matter expert)... then one likely only gets a popularized version of gossip.
"Wax"...as in automotive type treatments.... usually refers to two different types. There are "polish" types, which usually contain some sort of abrasive designed to remove oxidization and oxidized coatings (such as paint), smooth scratches, and return the object to a brighter, smoother, (i.e. lower) coat....and actually REMOVES material. (Not a good thing if your late-model Airstream has a valid clearcoat....but if you have an older painted or uncoated surface that needs oxidized surface removed,...can do wonders.)
Next there are true WAX types, the best usually containing carnuba, a So. American tree-wax, which leaves a protective film upon the surface, thereby protecting the surface against future oxidation.
Older automotive paints (those produced prior to the 1980's) were more subject to oxidation. Modern paint coatings are much better at resisting UV, Ozone, and oxidation/abrasion in the environment, although industrial sites (thinking here of the petrochemical plants in NW Corpus, or E. Houston, Pt Arthur, Tx, and portions of N.J., Chicago, StLouis, LA, Etc. ...can create envirionments that will defeat even a good clearcoat.
I.E., "polishing" clearcoat will eventually damage the protective nature of that coating. Newer Airstreams do not benefit and may actually be harmed by "polish" and other abrasive treatments if the clearcoat is harmed. While "wax" will not harm it... modern Airstreams and auto's, etc, which have polyurethane, plasticized, or similar coatings and paints only need to be kept clean with mild soap/water, and gentle bug/tar removers (WD40 is WonDer-ful.)
As for Filliform.... this is a type of corrosion which occurs when unprotected surfaces (like the cut edges of our riveted coaches) meet oxygen. Filliform is not usually structurally destructive...but it's a cosmetic eyesore. The only way to cure it is to remove it and protect it from oxygen. Too late for a coach that had it's sheet-metal already cut and riveted and exposed to oxygen.
But it can be treated. My advice is to remove the clearcoat directly over the filiform, and then re-polish the exposed aluminum, and then clean and re-coat the repaired area with automotive clearcoat which is available at auto paint suppliers. It is also found in small "fingernail polish" dispensers at WalMart, AutoZone, etc., and can also be found in aerosol rattle-cans for larger areas.
I've used an abrasive wheel (3-M) to remove it and then clearcoated it, and that has resulted in good appearance and seems to last. (Don't attempt to use the wheel directly on top of clearcoat because it will "burn" the clearcoat/plastic and load the wheel up with plastic. Also, be aware of the "grain"...or the direction of the milling-process on your Airstream. This is usually in a fore-aft direction on the coach. If you polish with the wheel in vertical direction it will leave a totally different level of "shine" that will not match the adjacent area.
My own boarding-assist handle at my Airstream door was totally covered in filiform and I used a 3-M pad (these are also found at groc. stores, usually backed with sponge/foam) to remove the clearcoat and filiform. I then wiped it down with alcohol (such as used in boat cooktops and paint stores or Home Despot) to remove residual dust, then painted the handle with automotive clearcoat. It looks like new!
Hope these comments help.
By the way... Jamie and I own a bare-aluminum airplane (non-clearcoated) that is over 60 years old and shines like a new silver dollar. My peers work like the devil regularly, polishing and shining and complaining about the hard work they put into their polished versions (the original factory did not paint their 1950's models)...but pleased with their results...and are usually very surprised to find out that their "Parts and MX Advisor" (I teach and moderate the mx website for the classic airplane type).. they are usually surprised to find that I never, and I mean NEVER, use soap or wax or polish on my shiny aluminum airplane.
I only wash it...and NEVER with soap... but ALWAYS with a couple cups of WD40 in a 5-gallon bucket of forcefully-injected water. I rinse the airplane, apply the WD40 solution with a cotton-mop and old towels, I rinse the airplane again, and dry it with old towels. It looks as good as it did the day it was made waay back in 1952. :>)
And the rubber window-seals, door hinges, window hinges, are all lubricated, and rainwater bubbles-up like a fresh-waxed surface! It also removes tar, bugs, etc. without harming the delicate surfaces. (My dad used to wash the family '57 Chrysler with kerosene/water solution, which he plagiarized from a book "Hints from Heloise." I just prefer the smell of WD40, which I buy in gallon cans.
Try it. I'll bet you like it.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 06-04-2016, 11:11 AM   #32
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
There's another option besides polish and wax - Liquid Glass. Liquid Glass is an acrylic polymer that never fades, dulls, yellows or cracks. After repeated applications it forms a kind of clear coat.
A little background...
I've fooled around with Porsches, mostly the 1965-1973 longhoods, for many years. I've restored them, raced them, and shown them at the concours level (and won a couple of times). Wax is a very big deal in the show context. I experimented with many waxes over the years, including the most expensive carnuba waxes. I experimented with various applicaton methods, including allowing the wax to warm in my hand before applying it. I eventually got good results, but it was expensive and a lot of work. Then a friend of mine with show winning Ferraris introduced me to Liquid Glass - I've never looked back.
Liquid Glass is easier to apply than most waxes as it just wipes right off and you don't have to worry about it drying too much and becoming difficult to remove.
My trailer is a '90 Excella with the plasti-coat that is generally in rough shape after 25+ years. I'm fortunate that the plasti-coat on mine is just about perfect and I'm doing my best to preserve it. Since I acquired it three years ago I have applied Liquid Glass twice a year - so far so good. It's stored inside in the winter but spends summers outside and there has been no degradation of the plasti-coat.
$80.00 a square foot!!?? That's a total upsell rip-off. A can of Liquid Glass costs $30.00 and will be enough for two applications, and it's a pleasure to apply. Great way to get to know your trailer.
Cheers,
John
John & Vicki
WBCCI #4291
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 06-04-2016, 11:45 AM   #33
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Ive owned lots of top shelf automobiles.... they all come with an offer of some.sort of paint shield at a huge price. The only one that has any merit is Waxoyl which protects the under and inner chassis components, not the paint or finish.
I think the rest are just snake oil. Buy a $9 bottle of NuFinish and some good beer. Do it yourself once a year and get to know your girls body.
Old 06-04-2016, 12:24 PM   #34
drboyd's Avatar
1978 25' Tradewind
$80 a square foot? In this part of the country you can buy a freakin' house for a hundred dollars a square foot
Cleaning/Waxing Aluminum Interior Toasty's Dad General Interior Topics 25 07-27-2015 10:20 AM
2004 Airstream needs a waxing kstampa Clearcoat, Exterior Paint & Trim 2 04-21-2008 11:18 PM
Am I polishing or waxing? 85Sovereign Cleaning, Stripping & Polishing 14 04-09-2007 08:38 PM
Waxing the finish Joan D'Andrea Cleaning, Stripping & Polishing 15 01-05-2003 06:32 AM
Washing/waxing "new" clearcoat Kistler 2002 - 2005 International 13 11-21-2002 10:27 AM
