Well, it's round two and I'm redoing the water system. There is a leak behind the toilet and I need to remove the unit. Can someone explain how it is removed? Also, the trailer is carrying two sets of club numbers. Is there a registry I could check to see where or who it came from? Any suggestions would be greatly appreciated. Thanks, Charlie
The stock toilet is held down by 2 bolts, 1 under the foot peddle, the other opposite that one that you get to through the top of the toilet under the seat is a small cover over the hole. That nut is way down at the same height as the other nut.
