Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-07-2011, 07:59 PM   #1
1972 25' Tradewind
Albany , Georgia
Images: 8
Water supply question at a state park.
Let me preface this post by saying I am an Engineer…
The wife and I took the airstream to Cheaha State park in Alabama. The camp ground had a water issue and I don’t understand what was happening. While at the park, we were connected to the camp ground water supply. Inside the camper, the flexible line between the pump and the copper line came off and spayed water in our camper.
After that, every time we left the camp, I tried to remember to shut off the valve supplying the water to the camper. Here is the thing I don’t understand. When the valve was on and supplying water to the airstream, there would be a leak coming up out of the ground just before the concrete pad where the water connection was located (upstream of the supply valve). This leak would turn into a small stream and run as long as the valve was on. When I cut the valve off, the leak would quit flowing and the ground around the concrete pad would dry.
Does anyone have an idea as to what would have been happening?
Why would a leak quit, when the valve downstream of the leak was cut off?
Will
meadowlm is offline   Reply With Quote
Old 06-07-2011, 08:12 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
That is a weird one...I have no idea why your turning off the water would stop a leak in the system before the valve!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 06-07-2011, 08:21 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
was it one of those no freeze type shutoffs where the lever or knob is above the ground but the actual valve is underground?
Old 06-07-2011, 08:25 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Many of the water valves in state parks are designed for freeze protection. If it is a handle that you raise and lower to turn the water on and off, the valve is located at the bottom of the supply pipe somewhere under ground. If that pipe had a leak it would stop when the water was shut off.
Richard
Old 06-07-2011, 08:31 PM   #5
1972 25' Tradewind
Albany , Georgia
Images: 8
I am not sure. It had a pipe sticking up about three feet high with a valve/lever at the top. Just checked it out at TSC. I understand now.
Thank you very much.
Will
Old 06-07-2011, 08:33 PM   #6
1972 25' Tradewind
Albany , Georgia
Images: 8
Now I can take that trip off on taxes. I learned something about piping. Alright!
Old 06-07-2011, 10:57 PM   #7
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Originally Posted by meadowlm View Post
Let me preface this post by saying I am an ....... When the valve was on and supplying water to the airstream, there would be a leak coming up out of the ground just before the concrete pad where the water connection was located (upstream of the supply valve). This leak would turn into a small stream and run as long as the valve was on. When I cut the valve off, the leak would quit flowing and the ground around the concrete pad would dry.
You are actually describing a correct operating frost free type valve. There is an engineered hole above the slug that closes on the seat at the bottom of the valve. When the valve is shut off, this drains the water in the stand pipe into a few cubic feet of prepared drainage gravel around the valve so it doesn't freeze in the stand pipe. When the valve is fully opened, the slug covers the drain hole so the hole isn't leaking. If you don't open the valve full on, the drain hole will bring forth great torrents of water down hole, causing great grief to the maintenence crew that has to repair the blown out hole and collapsed ground around the hydrant.
Your fire hydrants work this way also, they need to be fully opened. The firemen really hate mis trained folks opening fire hydrants only part way, this can cause water coming out the drain to blow out the support of the high pressure fire line. (It's fun to watch the fun on a construction job after the "underground" crew spends days looking for a leak in a hydrant and high pressure line, finally get it repaired to pass inspection on a Friday. Then that weekend the tile layers open up the hydrant part way to get a bucket or two of water and leave it open like that, washing out the compacted fill that I had just tested, the hydrant leaks again on Monday.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
Bastrop State Park (Tx) renovations Goal15 On The Road... 5 05-06-2011 03:03 PM
Split water supply line Eliminator46 Fresh Water Systems 10 05-03-2011 06:43 AM
Our visit to Crater of Diamonds State Park JitneyBead On The Road... 3 03-18-2011 08:25 PM
Ward Charcoal Ovens State Historic Park - Ely NV JamuJoe On The Road... 0 02-17-2011 10:07 AM
