Old 06-01-2019, 12:17 PM   #1
2017 23' Flying Cloud
Broomfield , Colorado
Water seems to be aerated from hot water tank
Water seems to be aerated from hot water tank.
I am new here, this is my first post if this is not the right place or you have suggestions please let me know.
The water coming from the water heater has lots of little air bubbles and reduced pressure, this is before I turn the water heater on. If I turn the bypass switch valve so that the water bypass the water heater the problem goes away. Iíve tightened every connection that I can find but canít seem to solve the problem. It does this with city water or from the water pump. Iím concerned if thereís that much air in the water heater it could be a problem.
Trailhead is offline   Reply With Quote
Old 06-01-2019, 12:44 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I see this is your first post. Welcome to the Air Forum!
There should be an air bubble, a cushion for expansion, inside of the water heater. This is normal. Do not activate the pressure relief valve or the WH will loose this bubble. Then the pressure relief valve might start dripping to relieve expansion when water is heated.
Aeration happens at the faucet, not in the water heater. You might unscrew the aerator and clean it if flow is reduced.
Have you flushed the water heater, prior to turning on the faucet? This is maintenance you should be performing (see the water heater pamphlet that came with the trailer )
PS
If hot water flow is reduced and if your trailer has a water tempering/mixing valve that is another thing that has a screen that captures particles when the water heater is not maintained properly. If this gets stopped up, it requires removal and repairing the mixing valve.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-02-2019, 11:46 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
After towing there is always air in the lines... you just have to let it clear. The hot water tank has the biggest bubble.
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Water heater seems bigger than the door! CodyWentling Water Heaters, Filters & Pumps 6 07-26-2010 01:08 AM
