Old 10-19-2015, 10:02 PM   #1
Water regulator replacement
Hi.
Just bought a 1988 Excella 1000 32' side bath. Seems from reading that the built in water regulator is gone. No city water getting in.
Does anyone know of a source/part number for a replacement. I do not want to rebuild it.
pepsigns is offline   Reply With Quote
Old 10-19-2015, 10:21 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Are you referring to the pressure regulator? They are not absolutely necessary. If you hook up to city water at high pressure (above 75 psi) you could blow some plumbing. But, you can get a water pressure regulator that you put on your inlet hose or hydrant that does the same thing for about $15.
Are you also saying you have no water pressure when hooked up to city water? Never heard of that.
Old 10-19-2015, 10:23 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Lumatic X2
Old 10-19-2015, 10:32 PM   #4
I am saying that!
Old 10-19-2015, 10:35 PM   #5
Originally Posted by TG Twinkie View Post
Lumatic X2
Twinkle. Lunatic x2 search seems to point to a gas regulator. Am I missing something?
Old 10-19-2015, 10:37 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
One possibility, although weird, is the PO removed the water regulator and capped off the ends. Do you see any capped off plumbing in the city water line?
Old 10-19-2015, 10:39 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Sounds like is originally talking about the city water pressure regulator aka pressure relief valve to me. No mention of gas.
Another possibility is a stuck or backwards check valve. Also weird.
Old 10-19-2015, 10:42 PM   #8
1979 23' Safari
Wayland , New York
Sounds like there might be a closed valve in there. Pressure regulator usually don't fail in a way that zero pressure gets by.
Old 10-19-2015, 10:59 PM   #9
No water is getting in at all.
Old 10-19-2015, 11:06 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
agreed
Old 10-19-2015, 11:09 PM   #11
Well unless there is a forcefield installed between the intake and the regulator.....
Old 10-19-2015, 11:13 PM   #12
Lumatic's Avatar
1993 34' Excella
Images: 16
In that case just degauss your flux capacitor
Old 10-19-2015, 11:18 PM   #13
It appears to be a watts regulator. I have a photo but I can't get it to upload. Probably the tribbles!
Old 10-19-2015, 11:42 PM   #14
1974 Argosy 20
Kooskia , Idaho
You can find pressure regulators at Home Depot, and even ones with sharkbite fittings on both ends. The ones I have seen are in the Sharkbite plumbing section. You need the 1/2 inch size. I am not sure of the brand, it might even be Watts, like the original one was.
What is this? maybe a regulator part?...any good web sources for replacement? FishHuntTX Fresh Water Systems 2 03-21-2014 03:27 PM
Pressure Regulator Replacement - HELP! lebolewis Fresh Water Systems 1 04-13-2010 11:42 AM
Advise for updating/replacement LP Line and Regulator 911rs LP Gas, Piping, Tanks & Regulators 1 03-02-2009 11:00 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
City Water Regulator odfarley Fresh Water Systems 2 08-26-2003 11:28 AM
