Old 04-12-2015, 10:42 AM   #1
1985 32.5' Airstream 325
Calgary , Alberta
Water Pump
I have just purchased a 1985 325 Airstream Motorhome and on the journey home we ran into a problem that I am not able to figure out. We had been using our fresh water supply for 3 days and 1 day I decided to use the "city supply" and when I went to unhook the line water started gushing out. I did turn off the supply line before unhooking hose. I had to turn off the pump so water quit coming out of the city water hook up. Any ideas?
jimbro is online now   Reply With Quote
Old 04-12-2015, 10:56 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is a check valve at the city connection that is to stop water from exiting there when the pump is on. Most likely that valve is stuck open allowing water to back-flow out.
Once fixed it is a good idea to turn the pump off while hooked to city water. I say this because during periods of low city pressure, in under supplied campgrounds, the pump will come on and unnecessarily draw you tank down.
I have taken the valve apart for other problems and you might try that as a first attempt to fix.
2004 Excursion 4x4
Old 04-12-2015, 05:08 PM   #3
Calgary , Alberta
Perfect. I will look at it tomorrow.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
