Old 05-16-2011, 10:36 AM   #1
2008 19' Bambi
Locust grove , Oklahoma
Ok, just bought 2006 Bambi and on maiden voyage trip but can't hook up water cause it is spraying out under the pedal that flushes the toilet.., And there is water leaking into the back compartment where you turn on/off drain valves, I guess I will look under the bed ...
It had been winterized because I put drain plug in water heater and closed back drain valves.... Is There something else I should have opened or closed or do I probably have breaks (which I suspect)... We had a brutal winter
Thanks for help
AirheadOK is offline   Reply With Quote
Old 05-16-2011, 11:55 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Sounds like winter damage. I blow out all my lines (hold the flusher down and open faucets) and then add RV antifreeze to be safe it's sounds like some water remained and froze during the winter. Sorry you had to go through this.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 05-16-2011, 11:57 AM   #3
2008 19' Bambi
Thx... I was wanting to make sure I didn't miss opening or closing some valves....
Old 05-16-2011, 03:43 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Look at the winterization kit made by Camco. I installed one of these and now use RV antifreeze every time it gets below freezing. No problems with freezing.
good winterizing info here
A W Warn is online now   Reply With Quote
Old 05-16-2011, 06:31 PM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
BlueSky - you mention closing valves, but did you drain and blow out all the water in your lines? Did you put antifreeze in?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 07:43 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Fresh water leak Stearns Fresh Water Systems 8 03-24-2011 09:52 AM
Water Leak in Plumbing eldin Fresh Water Systems 8 03-17-2011 07:43 AM
