Old 11-15-2014, 09:22 PM   #1
1994 21' Sovereign
Capitola , California
Water Leak Associated with Water Pump
After we used the fresh water pump the city water leaked and we cannot find the leak. It comes from under the trailer in the discharge area. My husband searched although the pipes and cannot find a leak. We happened to turn the pump on again and it stopped leaking. Yeah!
We were dry camping and used the pump again. It doesn't leak when using the water tank. Now the City water is leaking again in the same area. Does anyone have a possible explanation?
smattson is offline   Reply With Quote
Old 11-15-2014, 10:15 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like the city water pressure is too high. The pressure regulator or relief valve may be leaking.
Can you see where the water is leaking?
Is it inside the coach of out of the bottom ?
If it is the pressure relief. It should drain outside.
You might try an external pressure regulator to see if it helps.
Not a club I want to be associated with !!! The Manfam Off Topic Forum 4 09-14-2010 10:19 AM
Vintage AS and Politics associated with them? Pillow Member Introductions 16 03-14-2008 11:57 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
