Old 11-10-2018, 06:18 PM   #1
Aunt Fanny's Avatar
1995 33' Land Yacht
Omak , Washington
Water Leak
I just purchased a 1995 Land Yacht to live in this winter. When we hooked the water to it water came pouring out back around the spare tire. Water is running in bathroom but trickles in kitchen. Any tips to where it most likely is leaking would be appreciated!
Aunt Fanny
Aunt Fanny is offline   Reply With Quote
Old 11-11-2018, 11:11 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the water running out the belly pan? Or out of a tube thru the belly pan?
If it is out of a tube. Look for low point drain valve open.
It may be a pressure relief device since you have water pressure in the bath. This device releases the pressure by dumping water until the pressure set limit is met. If constant high pressure it will dump water continuously.
This device is not a regulator, it is a releif valve.
What is the city water pressure at your location.
I would try an external pressure regulator at the water source.
Does water run out when you use the pump?
If so. Look for a leak.
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 06:52 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 02:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 09:46 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-30-2005 12:03 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 11:52 AM
