Old 05-07-2015, 06:41 PM   #1
2014 23' International
Miller Place , New York
water leak
Please help new 27fb went to fill up water for holding tank major leak at low point drain valves need help. It is the one that has 2 petcocks for draining can I bypass it .Thanks John
mstrtek is offline   Reply With Quote
Old 05-07-2015, 07:18 PM   #2
Does any one know how to gain access to them the leak seems to be from the inside of the holding tank area
Old 05-07-2015, 07:41 PM   #3
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Your fresh water tank has one drain valve. It's white plastic probably located between the wheels. This valve can be really hard to turn.....be careful. The two brass valves are connected to the plumbing lines (1 hot, 1 cold). Are you sure the valves are closed?
Landrum is offline   Reply With Quote
Old 05-07-2015, 07:57 PM   #4
2010 28' Flying Cloud
Slidell , Louisiana
If you cant find a leaking connection, and if water is also dripping out of the small drain holes in the tank shroud or belly pan area,
check to see if your tank is cracked where the fitting is spin welded to the tank. One of AS rather common issues when use PEX as a rigid connection to the tank.
dayner is offline   Reply With Quote
Old 05-07-2015, 08:21 PM   #5
1979 23' Safari
Wayland , New York
The 2 "petcocks" aren't, they're valves, one hot one cold for low point drains. Close them, righty tighty, lefty loosey. Filling the fresh water tank is separate from connecting to the fresh water system. From your major leak description, you're probably hooking up fresh water supply hose to the fresh water system and it still has the low point drain's open.
From your description this is brand new to you, they could have been left open after winterizing, and haven't been closed.
Drain for the tank is located on the outside in the wheel wells, white plastic.
Old 05-08-2015, 05:23 AM   #6
Thanks for the input the 2 valves are for sure closed all the way one valve looks pushed up need to know how to remove the belly pan and check inside of it .Has any one done this ? Thanks pictures or diagram would help.
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
