It is a good possibility that the water is entering past the door gasket. I use a product made by Wurth that renews rubber door gaskets. Use it on all gaskets on the Airstream as well as vehicles. Check to see if you can push in on the door when it is closed, and if it moves inward you can bend the latch a small amount to tighten up. Also test with a garden hose spray on the door to imitate the rain on the door. You might have to look further if no water enters the compartment after you spray. Then it means starting to look higher up. Good luck!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
