Old 03-30-2012, 08:09 AM   #1
Delta , Colorado
water heater replacement
bought a 1975 27' overlander with a rear bath. the water heater is broken. I could use some help with where to buy a new one and could use some tips on how to remove the existing one - from the outside??
thanks for the help
jhlewis is offline   Reply With Quote
Old 03-30-2012, 09:05 AM   #2
x
XXXX , XXXX
Welcome to the forums first off.
I find that this place has the best prices for appliances.
Atwood Hot Water Heater on Sale - PPL Motor Homes
Removal is from the outside, there are several screws mounting the heater to the shell of the trailer. You will need to disconnect the water lines and the propane gas line. Both the water and the gas lines will need to be modified for the new heater.
wasagachris is offline   Reply With Quote
Old 03-30-2012, 01:06 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
If the tank is leaking you will have to replace it. Most other failures however are probably better repaired.
Old 03-30-2012, 02:07 PM   #4
Kristi Foster's Avatar
Jonesboro , Georgia
Images: 33
I have posted these pictures several times, but hopefully they are helpful to others trying to replace hotwater tanks and keep their original access door.Vintage 6 Gallon Bowen hotwater tank was replaced with a new 6 Gallon Atwood. The old Bowen housing was saved and the access door, by putting the new Atwood hot water tank into the old Bowen housing.Once the lines were taken loose from the inside, the old water heater housing was wiggled out from the outside.
Kristi Foster is offline   Reply With Quote
Old 04-01-2012, 12:10 PM   #5
Delta , Colorado
thanks for all the help. think I got it sorta out now.
Black water flush iathyme Waste Systems, Tanks & Totes 56 07-23-2013 03:09 PM
Solar Charger Replacement???? rhutson Generators & Solar Power 8 05-20-2012 09:57 AM
A/C and heater replacement paulrakel General Repair Forum 4 03-29-2012 10:15 AM
City water to Tank water transition? rhutson Plumbing - Systems & Fixtures 3 03-28-2012 08:48 PM
Healthy/Green Fresh water storage tank SteelyDan Classic Motorhomes 23 03-27-2012 08:55 PM
