07-14-2015, 08:24 AM
1993 21' Sovereign
Scaly Mountain
, North Carolina
Water Heater Drain Plug Broken
Stupidly, I over torqued the plastic water heater drain plug and broke it off in the water heater. I've tried digging the plastic from the internal thread to no avail. I bought a tap to clean the plastic out but can't get it started. Any suggestions?
07-14-2015, 09:00 AM
Biloxi
, Mississippi
Thankfully I have not had that problem. Something like this might work.
Screw Extractor Set 12 Pc
Or using progressively larger drill bits, drill the plug out a bit at a time. Carefully as to not damage the threads.
MICHAEL
07-14-2015, 09:03 AM
1987 32' Excella
Nepean
, Ontario
The extractor awchief suggests should work fine. Then replace the plstic/nylon plug with a brass fitting that has a valve on it - makes for emptying the tank much easier (for winterizing) and will not break like the plastic/nylon one.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
07-14-2015, 09:24 AM
1993 21' Sovereign
Scaly Mountain
, North Carolina
I have most of the plastic out except for that left in the threads. I've not been able remove that.
07-14-2015, 09:26 AM
Biloxi
, Mississippi
Time to dig out the dental pick.
MICHAEL
07-14-2015, 09:33 AM
1993 21' Sovereign
Scaly Mountain
, North Carolina
Thanks, I'll find one.
07-14-2015, 09:37 AM
Princeton
, New Jersey
You may have to make a pick strong enough to work those treads.
If you grind a pick I would heat it with a torch just before applying it to the treads. Hopefully that will cause the pick to melt into the tread and thus get a better grip. Once you break one tread it should be easy to peal the rest out.
Since that is a tapered thread I would start about half way and work the inner treads free first.
2004 Excursion 4x4
07-14-2015, 09:49 AM
2005 30' Classic
Burlington
, Ontario
An "Easy out" which is sort of like a reverse threaded tapered screw should bring it out without problem - you would need to drill a small pilot hole in the broken plastic pug in order to start the "Easy Out" into the plug.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
07-14-2015, 10:03 AM
Biloxi
, Mississippi
Brian.
See post #4
MICHAEL
07-14-2015, 10:06 AM
1974 Argosy 20
Kooskia
, Idaho
If this happens to anyone else, at the underground sprinkler section of your local hardware store, or big box store like Home Depot, they have what is called a nipple extractor. Generally under $5. You can drill a pilot hole in the plug and put the extractor in and unscrew the plug.
It would be of no use now to the OP as he is down to the plastic in the threads, but the product and advice might help someone else who is just starting out with a broken plastic plug.
07-14-2015, 10:27 AM
1972 27' Overlander
Woodburn
, Oregon
Snap on makes great small picks that would work great for this purpose , I use them all the time to remove " O " rings in small engine carbs you just have to find one of there trucks to buy one or you can order on line
07-14-2015, 11:27 AM
2020 23' Flying Cloud
Albuquerque
, New Mexico
Thanks!
I read these threads every day and I'm grateful for the shared knowledge. In this instance I was amazed by the effort you responders put in to help out, especially Idroba's contribution. It was helpful beyond the call. Thank you!
07-14-2015, 12:19 PM
2004 30' Classic Slideout
Fenton
, Missouri
I like to pull the plug annually so that I can scour out the insides of the tank. The original plug got a seam in it and started to drip. I went over to the local SOB dealership who is close to home and bought 3 black plugs. That way I carry a couple of extras in case one fails.
Galvanic corrosion can occur when dissimilar metals have contact with each other. Aluminum and brass are reactive to each other with aluminum acting as the anode. My Atwood tank in my Airstream is aluminum. Suburban branded tanks tend to be steel and have an anode rod in them to minimize corrosion.
https://www.fastenal.com/content/fed...0Corrosion.pdf
I imagine that other than cost factors, an aluminum tank is really better off using a nylon replacement plug to help maintain tank life. That's pretty much why I scour the tank annually to remove the deposits in the tank, and continue to use nylon plugs. I use a small adjustable crescent wrench to remove the plug. It works pretty good and doesn't scar the nut end. In addition I do wrap some teflon tape around the plug threads prior to reinsertion. That minimizes the amount of tightness you need to exert to keep the plug from leaking around the threads.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-14-2015, 01:10 PM
1999 25' Safari
Sparks
, Nevada
Drain Plug
I too have had this wonderful experience.
What I did was to use a sprinkler system riser removal tool to get the old plug out. That was however just the beginning. Seems that all the Teflon tape that I used over the years has become one with the water heater. I could not get a plastic plug to start SOooo I used a brass plug that I cut several slots across the treads to in affect make a tap. After several times of starting the plug into the heater enough Teflon was removed that I could get my new plastic (nylon) plug to start. I did use a dental pick to remove most of the remaining Teflon tape. I then found a 1/2 inch gray PVC type pipe about 2" long, both ends with male threads. I put on some Teflon tape and screwed it into the water heater. Now I use a female PVC threaded cap on the end of the pipe. When I wish to drain and clean and flush the heater I just unscrew the cap.
07-14-2015, 01:28 PM
Fenton
, Missouri
When I open the plug annually, i pull any residual tape off the threads in the heater. If you do this it pretty well eliminates the build up and it comes off pretty easily. If you let it build over time, I can understand that it can get a little nasty to deal with. I like to start with clean threads on both the plug and the tank.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-14-2015, 02:30 PM
1974 Argosy 20
Kooskia
, Idaho
The tool is the same one I was referring to. Your further ideas of the cut brass plug as a tap and plastic extension plus cap are excellent ones.
07-14-2015, 03:23 PM
2014 27' FB International
Clearwater
The mpt/fpt threads are under compression. Use a hacksaw blade to carefully cut the remaining ring into segments. Cut slowly to not damage the aluminum tank threads. With luck segmenting will release the tension allowing you to rotate out the plug ring. If not use a screwdriver to knock out a segment, use needle nose pliers to pull out the remaining segments. Replace with a brass plug or valve. I have used this process to remove mpt plugs and PVC fitting for years. Not pretty but it works.
07-14-2015, 03:32 PM
Mission
Echoing ChuckFeldt's removal technique as well as replace the plug with a (brass) valve ...
07-14-2015, 04:04 PM
2007 27' Classic FB
Tupper Lake
, New York
What about using a vacuum cleaner?
07-14-2015, 04:24 PM
1979 23' Safari
Wayland
, New York
Stick with a plastic plug to prevent corrosion. Hadn't thought of this earlier but it's making me think of my trip to tractor supply earlier. They make plugs that have a threaded port/hole in the middle that you can thread another smaller plug into. Not sure of plug size on the water heater, an inch or so. You could use a 1" plug with an internal 1/2" plug. May reduce chance of breaking smaller plug in the future.
