Old 07-16-2015, 10:11 AM   #29
Mission , Texas
Also curious, on another RV forum a master RV mech replied words like ...
On an aluminized tank (atwood) brass is okay, use teflon tape on the threads, and never use an anode (the metal the tank is made from does the anode job already).
For whatever it is worth ...
I think we need more certifiable RV mechanics. :/
nrgtrakr is offline   Reply With Quote
Old 07-16-2015, 11:01 AM   #30
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
When living on my boat down island I got in the habit of changing all my anodes (5) at least twice a year. I was prepared to do the same in my Airstreams. I was told sternly by two different experienced RV mechanics under no circumstances to use an anode in modern aluminum RV water heaters. Not necessary and can actually be harmful.
One also told me that he did not recommend the use of brass plugs with built in drain. Reason, it hampered a good forceful drain of the tank. Gunk and other goodies might not be sufficiently flushed from the tank. I currently have a brass drain in mine and plan on removing it next tank flush.
MICHAEL
Water heater drain plug - 2005 Classic 30 Wingeezer Water Heaters, Filters & Pumps 5 09-15-2012 06:32 AM
Atwood water heater drain plug nm1oqrz Water Heaters, Filters & Pumps 33 05-14-2011 09:30 AM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Bowen B10G water heater drain plug lebolewis Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-20-2008 11:49 AM
Needed, drain plug for hot water tank! wacnstac Fresh Water Systems 8 10-16-2007 08:22 PM
