Old 08-10-2014, 12:50 PM   #1
1976 31' Sovereign
Oswego , Illinois
Question water heater
Have bypass kit installed properly on heater, all valves turned way they should be to bypass or run strait, but when water is hot flush toilet get hot water into toilet, all lines are connected properly. Any one have this same problem. Ps I have installed a few bypass kits but this is a puzzler, also cold water lines to toilet are correct.
Old 08-10-2014, 01:09 PM   #2
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
If you continue to flush, does the water stay hot? The reason I ask is because if the toilet pipes are near the water heater the water in the pipes near the heater will heat up, but after running cold water displaces the hot water and it returns to normal.
I have this situation with my lavatory water. The pipes under my lavatory are near the hot water heater and water in that area warms up. When I turn on the cold faucet, warm water will run for a few moments before cold begins to flow out.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 08-10-2014, 03:35 PM   #3
1976 31' Sovereign
Oswego , Illinois
water heater
I don't think that is the prob. as water gets very hot, some times have to run water for several min. maybe a little more, but I will check it out when we go in couple of weeks. Thanks for this matter Bill
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
