Old 07-17-2014, 04:36 PM   #1
1969 23' Safari
fairfield , Pennsylvania
Question Water flow
I have a 1969 safari the cold water knob works water flows, but when I turn the hot water knob nothing I I need some advise on how to correct problem watchman2000.re@gmail.com
russellsue is offline   Reply With Quote
Old 07-17-2014, 09:03 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like you have the system in partial bypass mode for winterizing. And the valve on the hot water line is closed along with the bypass valve.
When "summerizing" the bypass should be closed and the hot and cold should be open.
Is " summerizing" a word?
Did you have water in the water heater? Did you light the water heater?
If you can't get hot water. It may mean that the water heater was not full. If you fired it up empty. It may have been damaged. So check for leaks.
Old 07-18-2014, 06:07 AM   #3
1969 23' Safari
Thumbs up water flow
You were right it was in winterize mode there was water in the tank when i opened the pressure release valve water came out hot
thanks
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
Water flow stopped suddenly dryan Plumbing - Systems & Fixtures 7 08-25-2008 06:25 AM
city water won't flow..help! AirSpleen Fresh Water Systems 9 08-20-2006 05:39 PM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
