Old 07-03-2016, 01:23 PM   #1
2003 30' Classic
Fresno , California
Waste valve cables
We are new owners of a 2003 classic 30. We just completed our first trip and I need some direction. Opening and closing both black and gray tank balves took a lot of effort. Does anyone have any advise on freeing these cables up a bit. I was a little scared I was not going to get them closed after tugging pretty hard to get them open. Any help would be appreciated.
ldireland is offline   Reply With Quote
Old 07-03-2016, 02:49 PM   #2
2003 30' Classic
Marengo , Indiana
Dump valves
Hi , Idireland.
We also are new owners of a 2003 Classic 30.
After we purchased ours we found out the rod that connects to the black tank valve was broken at the valve. There is nothing binding on the rods themselves, the problem is the valves. You can try to find something to put into the tanks to lubricate the valves, but if that doesn't work, the only thing left is have Airstream replace both valves. It's expensive, I know, but you will end up with brand new valves.
If you go the Airstream rout, also have them replace the fresh water tank drain. It will break sooner rather than later and you will not be able to replace it your self ( ask me how I know).
Also have them replace the bathroom fan with a Fantastic fan. Life is so much better with that upgrade.
And while your at it, upgrade the toilet. A new porcelain toilet is the way to go.
Good luck
Gene
l
Packard is offline   Reply With Quote
Old 07-04-2016, 06:24 AM   #3
2003 30' Classic
Fresno , California
Dump Valves
Thanks Gene, You give great advise and I will take all very seriously.
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
West Boondocking Waste Water and Food Waste Disposal Ray Eklund Boondocking 2 10-18-2015 02:38 PM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
