10-13-2014, 01:49 PM
#21
1999 34' Excella
Hillsboro
by 'valve' do you mean the vacuum break?
Peace and Blessings..
Channing
WBCCI# 30676
10-13-2014, 02:11 PM
#22
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
Get one of these Flush King - Valterra FK-01 - Sewer Flushing - Camping World. It lets you back flush the black tank with gray water and/or hose connection. Plus lets you add more water to the black tank for your next stop. More efficient than the AS flush connection.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
10-13-2014, 03:08 PM
#23
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley
, Georgia
Sorry, vacuum break.
10-13-2014, 04:31 PM
#24
Little Rock
, Arkansas
What do I win??? Just kidding. I know what I won!
I was already planning on removing that vacuum breaker on our AS. I'm just waiting until I winterize in a few weeks since I have to open things up anyway to install the winterizing kit on the pump.
10-13-2014, 04:39 PM
#25
Little Rock
, Arkansas
I don't believe the sheet mtl cover on my tanks has any drain holes in the bottom. I wondered what would happen if water got in there?? I even thought of putting tape over the openings for the valve handles so road spray wouldn't enter the box. Water could drain out the openings to the valve handles, but those are a couple of inches up from the bottom. Unless there are seams on the corners that could weep/leak the sheet metal box could hold several gallons of water.
10-13-2014, 04:42 PM
#26
2014 27' FB Eddie Bauer
Chelsea
, Michigan
Does anyone have a recommendation for a metal (brass) replacement for the vacuum break valve for the black tank flush that can be used to replace the POS plastic one from Airstream?
Bob Martel
WBCCI# 5766
10-13-2014, 05:32 PM
#27
Little Rock
, Arkansas
I wonder if this would work??
10-13-2014, 05:40 PM
#28
Chelsea
, Michigan
Attachment 224340
Very good Landrum. I will look for this at our nearest plumbing supply store in the next couple of days and install preemptively.
Thanks!
Bob Martel
WBCCI# 5766
10-15-2014, 01:08 PM
#29
1999 34' Excella
Hillsboro
Let me first admit my total ignorance...
I thought the 'black tank' wash device was totally separate from the potable water supply?
See.. I told ya I wuz a dummy...
Channing
WBCCI# 30676
10-15-2014, 01:22 PM
#30
Chelsea
, Michigan
It is, not connected at all. Why do you ask?
Bob Martel
WBCCI# 5766
10-15-2014, 02:39 PM
#31
Princeton
, New Jersey
It is not connected to the trailers potable water system but it is connected the the source water system when used, thus the need for a vacuum break.
While it is almost impossible to have a condition where the source system would pull a vacuum on the black tank while the nozzle was under water that is what the protection is addressing.
Do the world a favor. Don't ever use the thing.
2004 Excursion 4x4
10-15-2014, 03:11 PM
#32
2008 25' Classic
Full Time
I use everything in my AS, even the dump valve light .....well not everything, I don't use the phone jack
10-15-2014, 03:15 PM
#33
Biloxi
, Mississippi
I recently found out by accident that there was a dump valve light. I had been messing around my dump valve area few days ago. Came back out after dark and notice a faint glow by the valves. I guess I turned it on without realizing it.
MICHAEL
10-15-2014, 04:52 PM
#34
Sugar Valley
, Georgia
Got the new "valve" installed. Understandable why they crack. There is quite a bit of torque necessary to tighten the hoses enough to prevent leaks. That in turn puts the plastic bits in a bind. I'm thinking that if the hose from the hose connection to the bottom of the vacuum break were more flexible, less stress would be put on the plastic valve. Be easier to install also. In my humble opinion at least. Off to home depot. Thanks again, Mike
10-15-2014, 05:16 PM
#35
Sacramento
Hahahahaha....."Poop"........"Soup". Makes sense! Got a good chuckle out of that one!
10-18-2014, 11:22 PM
#36
Originally Posted by mojo
These are great, I've had mine for 6yrs.
