Old 10-15-2014, 01:08 PM   #29
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Let me first admit my total ignorance...
I thought the 'black tank' wash device was totally separate from the potable water supply?
See.. I told ya I wuz a dummy...
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-15-2014, 01:22 PM   #30
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
It is, not connected at all. Why do you ask?
Bob Martel
WBCCI# 5766
Old 10-15-2014, 02:39 PM   #31
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is not connected to the trailers potable water system but it is connected the the source water system when used, thus the need for a vacuum break.
While it is almost impossible to have a condition where the source system would pull a vacuum on the black tank while the nozzle was under water that is what the protection is addressing.
Do the world a favor. Don't ever use the thing.
2004 Excursion 4x4
Old 10-15-2014, 03:11 PM   #32
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I use everything in my AS, even the dump valve light .....well not everything, I don't use the phone jack
Old 10-15-2014, 03:15 PM   #33
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I recently found out by accident that there was a dump valve light. I had been messing around my dump valve area few days ago. Came back out after dark and notice a faint glow by the valves. I guess I turned it on without realizing it.
MICHAEL
Old 10-15-2014, 04:52 PM   #34
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
Got the new "valve" installed. Understandable why they crack. There is quite a bit of torque necessary to tighten the hoses enough to prevent leaks. That in turn puts the plastic bits in a bind. I'm thinking that if the hose from the hose connection to the bottom of the vacuum break were more flexible, less stress would be put on the plastic valve. Be easier to install also. In my humble opinion at least. Off to home depot. Thanks again, Mike
Mike S. is offline   Reply With Quote
Old 10-15-2014, 05:16 PM   #35
Sacramento , California
Hahahahaha....."Poop"........"Soup". Makes sense! Got a good chuckle out of that one!
HASANCHEZ is offline   Reply With Quote
Old 10-18-2014, 11:22 PM   #36
Originally Posted by mojo View Post
Get one of these Flush King - Valterra FK-01 - Sewer Flushing - Camping World. It lets you back flush the black tank with gray water and/or hose connection. Plus lets you add more water to the black tank for your next stop. More efficient than the AS flush connection.
These are great, I've had mine for 6yrs.
0557 is offline   Reply With Quote
flushing out the Black Water Tank... wesmoss Full-Timing 2 08-08-2014 09:59 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Getting Out The Black Tank Silverslug75 Waste Systems, Tanks & Totes 5 08-05-2009 04:51 PM
P3 LCD washing out davidz71 Brakes & Brake Controllers 9 07-17-2007 08:12 AM
Changing out the Black water tank AccessMaster Airstream Motorhome Forums 8 08-30-2003 08:03 AM
