Old 07-03-2015, 07:43 PM   #1
grumpys's Avatar
2014 Interstate Ext. Coach
Grove City , Pennsylvania
Question Warning on Dashboard
This warning came on after we crossed rough section of road. Later we filled up and the warning went from 10 starts remaining to 9 starts remaining after the engine was started. The check engine was lit up before this happened.
grumpys is offline   Reply With Quote
Old 07-03-2015, 08:43 PM   #2
2007 25' Safari FB SE
Suburbia , Sunny So Cal
What vehicle and powertrain are we talking about?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 07-04-2015, 05:02 AM   #3
grumpys's Avatar
2014.5 MB chassis.
Old 07-09-2015, 04:20 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Low DEF, perhaps?
Old 07-09-2015, 06:55 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not enough information to even hazard a guess. The "check engine" light can come on for almost any problem. The "countdown-to-breakdown" can also occur for several reasons.
It's possible that you have multiple messages in the data display, but you're only seeing the most critical one. Try using the up and down buttons on the left side of the steering wheel to see if you can cycle through the messages. A message that's hidden by the countdown may tell the tale.
On Edit— You should be able to cycle through the message screens with the key in the "accessory" position so that you don't waste one of your few remaining starts just to read messages.
And don't delay in getting your van to a Sprinter dealer— when you get to "0" starts remaining, you're looking at getting it towed. That's a completely different problem all in itself, and I suggest that even though you have a few starts left, you should temporarily make a habit of parking it where a tow truck can get to the front end to hitch up; it's hard to manhandle a big van like that if it's not positioned for easy access by the tow truck.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Warning! Birchwood. Warning!!! austreampete Commercial Listings 1 01-10-2004 08:04 AM
