Old 07-17-2018, 05:55 AM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Vulkem Questions
When folks write about Vulkem are the referring to Vulkem 116?
Is the gray Vulkem the right product for sealing the gray belly pan aluminum to the plastic Banana wrap?
Exactly when is the right use for Vulkem?
Thanks.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 07-17-2018, 07:12 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Most folks are referring to Trempro 635 which as I understand it used to be called Vulkem.
https://www.vintagetrailersupply.com...-p/vts-267.htm
Fastenal has it sometimes but the last I bought from them was old in the tube so I'd get it from Steve at VTS.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 07-17-2018, 10:20 AM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
You can use gutterseal from home depot too. Great stuff blends in well
Matt
rugjenkins is offline   Reply With Quote
Old 07-17-2018, 08:20 PM   #4
Re-Pete's Avatar
1992 29' Excella
Thanks 68 TWind, I'm familiar with Trempro 635, I have some actually, but I'm not sure it's what I need for undercarriage work.
Pete
Virginia Beach, VA
Old 07-17-2018, 08:21 PM   #5
Re-Pete's Avatar
1992 29' Excella
Hey Matt, which brand is that?
Pete
Virginia Beach, VA
Old 07-17-2018, 08:44 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thanks.
The Vulkem of old is no longer made. The new Vulkem is not the same as was available 20 years ago. The name hangs on for some reason.
When I walk in the store at Out of Doors Mart and pickup a tube of Trempro off of the shelf it will sometimes have their price sticker with Vulkem printed on it. They advertise it the same way. (see link) I think they are telling us something. That's what I used 99% of the time.
http://odmrv.com/catalog/index.php?m...roducts_id=582
I think that Trempro is the closest thing you will find today to the old Vulkem. Any good high solids polyurethane caulk with UV resistance will work.
ODM used to have a video available at their website that showed one of their techs demonstrating the proper method of using Parrbond to seal the top of the beltline. I've used that for 20+ years, but recently I tried Lexel, as an experiment. Seems to be holding up well.
add edit
this does not apply to units recently made. Airstream has changed products in the last several years.
Alan
Old 07-17-2018, 09:54 PM   #7
Re-Pete's Avatar
1992 29' Excella
add edit
I'm going to take everyone's word on this one. I guess I hadn't heard this before. I've shopped at ODM also, and I recall them using another product, Adseal, besides Tempro and Parrbond. They used it on my roof.
The Vulkem 116 product that I saw is a polyurethane caulk, also.
Anyway, thanks to all of you for your hep.
Pete
Virginia Beach, VA
Old 07-18-2018, 08:27 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Adseal is silicone. I would not use that anywhere on my trailer, even though Airstream has started using it. When maintenance is needed, no caulking will stick to it or to the surface it was applied to (without some rigorous removal and cleaning).
Alan
Old 07-18-2018, 10:24 AM   #9
Ayr , Ontario
Thanks.
That is what I use for around the windows and door. I use Sikaflex 221 for most other applications.
https://www.homedepot.com/p/Tremco-1...3006/202267308
gator.bigfoot is offline   Reply With Quote
Old 07-18-2018, 11:09 AM   #10
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
This is a link to the data sheet for Tremco Vulkem 116.
Notice that its recommended uses are based on concrete and masonry, not metal. I agree that it will work, but have also wondered why metals are not specifically noted on the data sheet.
https://www.tremcosealants.com/files...kem_116_DS.pdf
Alan
Old 07-19-2018, 05:51 AM   #11
Ayr , Ontario
I purchased mine from an Air Stream specialist. That is what they use and recommend. I've used it and it works well to date.
Old 07-19-2018, 06:06 AM   #12
r carl's Avatar
Lin , Ne
So would that be an improvement or cost saving change?
Old 07-19-2018, 08:06 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
An executive decision, so it may be neither.
Alan
Basic questions on applying Parbond and Vulkem Jammer Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-15-2018 07:22 PM
Sikaflex 221 & Vulkem Questions Hans627 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-27-2016 07:22 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 08:06 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
