Old 07-02-2018, 10:32 AM   #1
1969 18' Caravel
Greenville , whereEverIroam
Vulkem or Sikaflex?
Noticed a leak around the exterior plastic range vent, looks like it needs to be resealed. There are so many sealants out there, am wondering which is best. Vulkem, Sikaflex, Acrylix, Walbernize, Silicone or some other caulk?
Looks like Airstream no longer has link to their airstream store on their website.
skyguyscott is offline   Reply With Quote
Old 07-02-2018, 10:48 AM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Sikaflex 221 is my go to. Order on amazon
Matt
rugjenkins is offline   Reply With Quote
Old 07-02-2018, 10:54 AM   #3
2011 22' Sport
Portland , Oregon
I read most of the master sealant thread discussion last year and created a "summary" for what was then the current consensus, sorry if only formatting is lost here:
For wheel wells/underbody:
Vulkem 116
Trempro 635 Grey
Sikaflex 221 Black (use Eternabond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams, seals and bonds. Use Eternabond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
EternaBond® AlumiBond (alum. backed sealing tape, 2", 3", 4", and 6" wide)
Lexel™ Clear
Windows/Trim/Rubrail/Exterior Lights:
Sikaflex 221 Grey (seals and bonds. Use Eternabond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes, prep and clean-up use cosmoline remover)
Trempro 635 Grey
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Lexel™ Clear
Small seams (between aluminum panels):
Acryl-R (available in cans from Airstream store. Use applicator or disposable syringes to apply)
Aluminum Pigmented Gutterseal
Rivet sealer:
Captain Tolley's Creeping Crack Cure
Parbond Gray or Clear (small hand tubes), also good for small gaps (<1/8”) such as top of belt line rub rail, door/window frames, etc
SilverHouseDreams is offline   Reply With Quote
Old 07-02-2018, 10:55 AM   #4
1973 Dodge Cayo Motovator
Outbackga's Avatar
Dahlonega , Georgia
Agree on Sikaflex. NO silicone, it pulls apart under stress and captures water!
Outbackga is offline   Reply With Quote
Old 07-02-2018, 11:00 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
3M 4200 have been using it for years to seal anything I may want to remove at a later date.
Started using it on the boat but found it works just as well on the AS. 👍
I use the 5200 on any permanent sealing, as in dump valve seals.
Extreme Sealing tape on the roof.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you can’t."
Amanamus
Sweet Streams....🌥
Sikaflex 221 & Vulkem Questions Hans627 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-27-2016 08:22 PM
Sikaflex 1a sealant Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-22-2015 03:24 PM
Vulkem, sikaflex, dicor flyfishrra Roof Vents, Skylights & Fans 5 09-18-2012 04:29 PM
Storing Vulkem or Sikaflex cameront120 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-30-2007 06:24 PM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 09:06 PM
