Old 05-03-2013, 02:02 PM   #1
1975 31' Sovereign
Royston , B.C.
Vista Views
I have gasket problems with my vista views. It seems the rubber gasket has shrank and leaked over the years. It also seems that theymight have been double paned at one time but not now. Can I buynew gaskets, should I just caulk inside and out, should I try to make them double paned again? I also have a few wires coming out of the wall behind the fridge spot, anyone know what these are for?
Pablito is offline   Reply With Quote
Old 05-03-2013, 02:27 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You should have had double pane glass Vista Views, there is a slight chance if your unit was an early 1975 that you had the snap in plastic inner panes. If you have single glass and thy have a rubber gasket around them you probably had the snap in version. I have cut back the gasket on the outside with a very sharp razor knife then taped and caulked them vulkem with reasonable sucess.
Aaron
WBCCI #XXXX AIR #2495
Sealed Vista Views with Parbond. Didn't work. adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 23 08-15-2011 11:17 AM
'75 Trade Wind Vista repair. Breadbug Windows & Screens 8 01-30-2011 05:11 PM
Temporary Seal for Vista views AluminumGirl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-08-2011 11:06 AM
