Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 10-08-2017, 08:43 PM   #1
2016 26' Flying Cloud
Southlake , Texas
Vista View Window Rivet
I was doing my semi-annual Corrosion-X application on all edges and rivets and discovered one of the vista window rivets coming out. I assume it has backed out because I didn't see it last time. It is on top of the vista window by the door and is almost covered up by the awning. The most obvious and easiest solution would be to leave it as is and just seal it. The rivet is not loose, but it's obviously not holding anything. It's has backed out about 1/8". If it wasn't under the awning, I would simply drill it out and replace with an Olympic rivet. I have the tool to finish off the top of the rivet, so it would look like nothing had happened. If I take off the interior trim on the window, would I gain access to the back of the rivet?
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 10-10-2017, 09:42 PM   #2
Southlake , Texas
Has anyone had the interior trim off a vista view window? I'm assuming that's what you call the skinny oval window above the main windows.
Equalizer Hitch
Old 10-11-2017, 06:50 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Not sure on a 2016, model but on earlier trailers the bucktails can be seen by removing the interior trim. If the rivet has not been bucked then a bucking bar can be held on the manufactured head and the bucktail formed using a hammer and punch on the inside (if accessible).
Old 10-11-2017, 08:18 AM   #4
Southlake , Texas
Thanks for the reply. I will take the inner trim off and report what I find.
Equalizer Hitch
Old 10-11-2017, 04:43 PM   #5
Southlake , Texas
I removed the trim and the backside of all rivets is exposed. The rivet goes through the outer skin and a 1" angle. It appears that it was never bucked. The end is not smooth like all the others. I will get my wife to hold a 2 1/2# hammer against the head of the rivet while I work it from the inside. I will put some Vulkum 221 around the rivet beforehand.
Thanks for the help.
Equalizer Hitch
Old 10-11-2017, 05:42 PM   #6
Aerowood's Avatar
Arvada , Colorado
Post a pic when your done
Old 10-11-2017, 08:30 PM   #7
Southlake , Texas
I should've said Sikaflex 221. And, yes, I will post pictures.
Equalizer Hitch
Old 10-13-2017, 08:57 AM   #8
Southlake , Texas
Rivet is fixed. Only problem I had was that I either needed a heavier hammer to buck with or a heavier/stronger wife! I put Vulkum under the rivet before bucking.
ID:	296891   Click image for larger version
ID:	296893   Click image for larger version
Equalizer Hitch
Old 10-13-2017, 11:33 AM   #9
Aerowood's Avatar
Arvada , Colorado
Where you able to push the rivet all the way in before you re- bucked it?
Old 10-13-2017, 05:05 PM   #10
Southlake , Texas
Yes. Since my bucking hammer and my wife were not heavy enough, I had to tap the rivet back in a little after each strike from the inside. It finally expanded enough that it wouldn't move.
Equalizer Hitch
Vista View window repair/replacement 83Excella Windows & Screens 16 03-05-2021 08:03 PM
Vista View window repair Bluegirl Windows & Screens 9 03-10-2017 11:38 AM
vista view window removal? DAVE SWANSON Member Introductions 3 07-24-2006 06:58 PM
Removing Vista View window on '68 Overlander 68Overlander Windows & Screens 2 06-27-2006 05:21 PM
Need help with my Vista View window. TBKP's Overlander Windows & Screens 1 07-05-2003 07:58 PM
