Old 06-17-2009, 02:44 PM   #1
1996 33' Land Yacht
tucson , Arizona
Vinyl stripe painting
I have a 1996 Land Yacht 33. The vinyl stripes are beginning to fade and crack. I was wondering if anyone has had the experience of painting over the old stripes?
What kind of paint did you use?
Preparation for painting? Do the old stripes need to be removed?
Any hints would be appreciated.
I just added a new wood floor from the kitchen to the rear bed room. picture attached.
Thanks in advance.
pacer is offline   Reply With Quote
Old 06-18-2009, 07:15 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Nice looking job on the floor!
I'm not sure about the stripe question. Let's throw it back out to the members again. What's the best way to restore stripes?
5 meter Langford Nahanni
Old 06-18-2009, 07:30 AM   #3
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Definitely remove the old stripes. Enamel may react with the vinyl, or not adhere. The stripes will continue to deteriorate even though painted over. Removing is a pain in the butt, but the result is worth it.
Alwhisman is offline   Reply With Quote
Old 06-18-2009, 08:46 AM   #4
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
Stripes
Nice flooring!
Remove vinyl stripe, get all glue off, use an aluminum primer in the area you wish to paint over (Spray paint from Lowes) tape off areas with blue painters tape...wait for paint to dry to add additional colors....accent with pin stripes (from auto paint store). Should outlast the decal stripes. Attached is one I did for my 85 Sovereign 25'.
Good Luck with your project.
Levon
Levon is offline   Reply With Quote
Old 06-18-2009, 12:47 PM   #5
buda's Avatar
Nice floor, I am thinking of doing mine.
I would like to know the blue used on the airstreams.
Is there a color code number.
Buda 71/23 Safari
buda is offline   Reply With Quote
Old 06-18-2009, 01:22 PM   #6
Tech Source
mdyeargin's Avatar
2006 22' Safari
1994 34' Excella
1977 31' Sovereign
Nashville , Tennessee
Send a message via MSN to mdyeargin
Restored 31' 1976
When I did my 31' 1976 I found that I could color match the paint at the auto/body shop. I had to do the stripe, lettering, and hub caps. I did not use a primer, but did use a product known as Toluene (not suggested any longer). I used a model air spray with the automotive paint. After letting the blue cure for about a week, I went back and did the pin stripe and such. After all of that cured I put two coats of lacquer. Be sure to tape very well as clean up of errors takes a lot of cotton swaps.
mdyeargin is offline   Reply With Quote
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 01:35 AM
Painting interior vinyl? 415Hoop Upholstery, Blinds, Walls & Interior Finishes 2 05-16-2007 12:46 AM
Painting over vinyl/plastic veneer on cabinets suzylugz Cabinets, Counter Tops & Furnishings 14 08-27-2006 06:20 PM
Painting the vinyl coated... geof Upholstery, Blinds, Walls & Interior Finishes 1 04-28-2003 10:37 PM
