Old 11-30-2013, 08:58 AM   #1
pt1949's Avatar
1992 29' Excella
LAS VEGAS , Nevada
VIN Plate
Where is the VIN plate located on my 92 Excella? Can't find it. I am sure I am just missing it somewhere simple. Thanks
pt1949 is offline   Reply With Quote
Old 11-30-2013, 09:54 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The VIN is stamped on the top of the "A" frame curbside on my 2013 25FB with a decal street side just behind the front section joint to the main body of the trailer. It got hidden on the "A" frame when my Hensley hitch parts were mounted....
Old 11-30-2013, 10:45 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The VIN tag is on the streetside front side sheet, near the rubrail. It will contain VIN, weight, date of manufacture, and a FVMSS statement.
Old 11-30-2013, 12:42 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I appear to be missing the VIN plate on my 1970. The VIN appears next to the door where it says Airstream Overlander, but there isn't a plate with axle weights, trailer weight, or manufacture date anywhere to be found on the skin. I hold a clear title, and would like to find/replace the data plate. Does anyone know how I can go about that? The factory doesn't have them going back that far.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-30-2013, 01:30 PM   #5
Well Preserved
1993 21' Sovereign
There wasn't a VIN, or any other data, prior to about 1981. Some later trailers had the GVW and axle ratings on a separate tag on the front panel, on the left, near the A frame. Some of those tags stated Airstream was a division of Beatrice Foods. I don't think that started until circa 1972 or so.
