Old 08-12-2018, 12:47 PM   #1
Barretta2's Avatar
2013 23' Flying Cloud
Naples , Florida
Very bent stabilizer.
A largish rock decided to tangle with my forward curbside stabilizer. Rock won decisively. If I take AS to a garage and ask them to bend it back, might there be sufficient metal strength to continue to use? Or will metal fatique make it just snap off when straightened? It is bent about 60 degrees sideways.
Thanks.
Barretta2 is offline   Reply With Quote
Old 08-12-2018, 01:17 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Iím not qualified to give the advice Iím going to give so take this with a salt lick.
Iíd replace it. 60% bent - by the time you get it back to straight, it will be weakened like a magicianís spoon bending trick. Even though theyíre only meant to stabilize (and not lift) the trailer, and even though the wheels (esp. if a double or triple axle) will take most of the weight, itís probably worth replacing with a fresh one.
Not an engineer here - just offering free advice worth everything you paid for it
Good luck!
Old 08-12-2018, 08:05 PM   #3
Eric 26 Argo's Avatar
Knoxville , TN
I would have to agree with Steve. Once the leg has bent it will not hold the same weight. There is also the issue of trying to bend it back into shape. All I can say there is good luck. The leg is thick enough metal that it would take a good size press and a knowledgeable individual to get it straight again.
Eric 26 Argo is offline   Reply With Quote
Old 08-12-2018, 09:13 PM   #4
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Steve is right, dang it, not worth fooling with.
It’s $100 for a new one
Bent Stabilizer Eric 26 Argo General Repair Forum 6 07-16-2018 07:30 PM
Bent Stabilizer Jack - Need Replacement dbj216 General Repair Forum 4 01-19-2013 09:23 AM
bent stabilizer funkill Jacks, Stabilizers, Lifting and Leveling 13 03-28-2009 07:48 AM
Bent Stabilizer Sierrapapa Jacks, Stabilizers, Lifting and Leveling 11 11-21-2008 11:54 PM
very old and very new horsefoot Member Introductions 4 10-02-2007 08:43 PM
