Old 02-06-2016, 01:57 PM   #1
2011 30' Flying Cloud
Greenback , Tennessee
Ventline Bath Fan Problem
I have a 6 1/4 inch Ventline fan in my bath that is not working. I initially thought I should replace the entire unit, but in my Amazon search, I have found a couple of motors that are used in those fans. The price is certainly better, and I may be able to replace the motor without removing the entire housing, recalking, etc. I found a nice video on replacing the whole unit, but I wonder if anyone here has replaced a motor. I will, of course, check out the switch before doing either. Any assistance will be appreciated.
Richard
Gneiss Guy is offline   Reply With Quote
Old 02-06-2016, 02:20 PM   #2
Richard
Rich.
Make sure the motor is getting 12 volts.
Better to make "real" sure before spending any amount of money.
If no voltage is going to the motor, it could be the switch or even a fuse.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-06-2016, 03:08 PM   #3
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
I had a problem with the same bath vent fan. After testing, I found the problem was in the switch. I replaced the switch from below in the bath and it works fine now.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 05-22-2020, 11:43 AM   #4
Projet2907's Avatar
2017 19' International
Rosemere , Quebec
I am not very electrically enclined, I have a voltmeter, how do you test the switch? where did you buy it? do you have a part number? I suspect the switch because at the beginning it was intermittent. thank you !
Projet2907 is offline   Reply With Quote
Ventline Bath Vent Gasket Replacement 2dabeach Roof Vents, Skylights & Fans 10 08-24-2020 02:48 PM
Replacement Cap for Ventline Bath Fan SSChanger General Appliance Topics 3 01-20-2019 10:20 AM
Ventline / Vanair VP-543 bath fan parts jm2 Roof Vents, Skylights & Fans 0 08-25-2010 01:41 PM
Ventline round shower and bath vents Darrell Root Roof Vents, Skylights & Fans 1 10-09-2006 04:56 AM
Ventline 6.25 inch exhaust fan Darrell Root Roof Vents, Skylights & Fans 2 07-14-2006 06:07 AM
