Old 09-22-2008, 05:54 AM   #1
Lothlorian's Avatar
Loganville , Georgia
Ventilation pipes
I took off the screen over the stove to check out the exhaust fan of my 73Ovelander. To my surprise there was no grease and it worked like new. the problem was all the wasp and hornet nests all over in there. I got up on top of the coach and checked out the vent cover. I noticed the screen was gone. I went down to the vent cover for the oven and noticed the vent screen torn also. My question is how do you clean the vent pipe to the oven? I do not want to knock dirt down on the oven. It is very obvious the oven has never been used by looking at the inside. It still looks brand new and I want to test it.
Lothlorian
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 09-22-2008, 06:03 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Brian, I think you are talking about a plumbing vent. I don't remember seeing a vent to our oven.
Is it the vent that has the cast aluminum cover, with a piece of nylon screen, and a rubber gasket?
Old 09-22-2008, 10:34 AM   #3
Lothlorian's Avatar
I think it is. It is left of the stove vent down a few feet.
Lothlorian
Brian
Brian & Adrienne
Old 09-22-2008, 11:18 AM   #4
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I think Terry is right on the money. My stove isn't vented to the outside either.
www.nesa.org
Air No. 6427
Old 09-23-2008, 11:38 AM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
parts
Here are the links to the parts mentioned.
cast aluminum cover
piece of nylon screen (aluminum here)
rubber gasket
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 09-24-2008, 03:08 AM   #6
Lothlorian's Avatar
Thank you very much for the link. I think I can make my own gasket. I might be able to make my own screen also.
Brian
Brian & Adrienne
Old 09-24-2008, 03:42 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Brian
I did...bought a chunk of fiberglass screen and grabbed a chunk of 45 mil EPDM scrap from the project down the road. Set the cover on it, trace around it and cut about 1/4" bigger to allow for the curvature of the trailer. Cut the center hole a bit smaller than the pipe for a very tight fit.
Aaron
WBCCI #XXXX AIR #2495
Old 09-24-2008, 05:31 AM   #8
Well Preserved
1993 21' Sovereign
If you want to go the really economy route, you can get a piece of nylon window screen from a hardware store, and an inner tube, and cut them both to fit. You should wind up with enough for all the vents for about $5.
Old 09-25-2008, 03:21 AM   #9
Lothlorian's Avatar
Thanks for the info. I have made my own gaskets before for other things. Saving where you can is a good thing these days.
Lothlorian
Brian
Brian & Adrienne
what pipes to use? kamo Fresh Water Systems 3 10-23-2006 02:58 PM
A/C, Ventilation, and Heating Choices air19 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-11-2005 09:31 AM
busted pipes sfixx Fresh Water Systems 36 04-07-2005 08:51 PM
Ventilation during storage TomW Roof Vents, Skylights & Fans 2 03-26-2004 01:14 PM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
