Old 07-16-2016, 06:46 PM   #1
hippiechick's Avatar
1966 24' Tradewind
versailles , Kentucky
Vent stack Question
On the roof this week cleaning and sealing. There are three vent stack penetrations that have a pot metal collar and the black pipe protruding above. Is this the original configuration? We have gutted the trailer and removed the black pipe currently. When you looked down onto this hole the pot metal housing is on top of the shell and on the inside of the housing is a black rubber donut. I cannot locate a replacement rubber gasket like this. Any help is appreciated.
hippiechick is offline   Reply With Quote
Old 07-16-2016, 07:28 PM   #2
1966 24' Tradewind
Meant to note that this pic was from another poster.
Old 07-16-2016, 07:39 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If it were me I would go to a local commercial industrial roofing company and ask if they had a scrap of EPDM rubber (or any other similar) sheet left over from one of their projects. Or go to a tire shop for a scrap of an old inner tube. (sheet roofing will last 20+ years exposed to direct sunlight. Rubber tube a year or two) Cut it slightly larger than the perimeter of the metal cap then cut a 1" or smaller hole in the rubber directly over the pipe so it will vent. Caulk the perimeter of the metal/rubber except leave a small weep on the low side so water can escape. Any rain water that would go down the vent pipe would not be an issue. Any water that went inside the metal cap on top of the rubber would weep out.
Another option would be PM Inland Andy. I've seen several post he has made about replacing these gaskets, so he probably has them in stock. I looked but could not find them sold individually on his website or ODM.
edit: found this so you can see the gasket. Note the screen they supply to keep the bugs out.
http://www.inlandrv.com/catalog/prod...roducts_id=167
Alan
Old 07-17-2016, 05:02 AM   #4
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
I cut an inner-tube, (remember them?).
Name:	SOLAR PANELS; ROOF LEAK 020.jpg
ID:	267038   Click image for larger version
Name:	SOLAR PANELS; ROOF LEAK 017.jpg
Name:	SOLAR PANELS; ROOF LEAK 011.jpg
"What you do speaks so loudly, no one can hear what you say"
M. Levy
So when is this..."old enough to know better" supposed to kick in?
Old 07-17-2016, 08:07 AM   #5
1964 24' Tradewind
Lawrence , Kansas
I found rubber gasket material at the hardware store and cut it to fit. Seems to work and stopped a leak.
ttbikes is offline   Reply With Quote
Old 07-17-2016, 08:29 AM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We bought one at Inland RV. Out of Doors Mart also sells them, I think.
Kay
Old 07-17-2016, 09:34 AM   #7
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I tried to replace mine with rubber gasket material I bought at the hardware store. It did not last long at all (less than a year) before hardening and cracking. I then bought some "factory" replacements from Out of Doors Mart, but haven't installed them yet.
good luck!
Old 07-17-2016, 09:47 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Found them!
http://odmrv.com/catalog/index.php?m...keyword=380114
In the photo the vent pile is down lower than it should be. The pile should be above the roof at least an inch or so.
Alan
Old 07-18-2016, 12:40 PM   #9
1966 24' Tradewind
Thanks so much for the suggestions and the link - but I'm a bit confused. These gaskets or inner tubes are flat. The one in mine looks fat like a round donut. Am I missing something here? This is a picture of mine. Not very good. It's soooo sunny it's hard to see this iPad. Valarie
Old 07-18-2016, 01:04 PM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
This is how I redesigned mine
Aluminum vent stack caps for 1968 Sovereign cheetah1 Exterior Restoration Forum 13 05-03-2016 10:50 AM
Vent stack question stevealbrech Waste Systems, Tanks & Totes 4 06-03-2014 07:51 PM
Vent Stack Replacement Opinion Ganglin Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-06-2012 09:07 AM
Vent stack covers silverhawk Roof Vents, Skylights & Fans 3 02-03-2004 04:35 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
