Old 10-18-2012, 01:45 PM   #1
1982 34' Limited
Harrowsmith , Ontario
Vent gasket caulking
I'm hoping someone can clear up how to properly caulk (Vulkem) the stack vent gasket. I've seen some people who caulk the whole exterior and others who suggest all sides but the bottom.
I'm also wondering if I need to seal between the gasket and the pipe. The existing ones were not but that doesn't mean it was correct! I put the screen above the pipe and gasket thinking it would result in a better seal without the gasket sitting in the screen.
Anyone want to share their thoughts? Thanks!
BradB is offline   Reply With Quote
Old 10-18-2012, 02:31 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Did you buy a new gasket & screen? Caulking is not going to do any good without fresh rubber gaskets.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-18-2012, 02:42 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
http://www.airforums.com/forums/f456...tml#post680585
Old 10-18-2012, 06:03 PM   #4
1981 31' Excella II
New Market , Alabama
I am going to come up with a fix before long that will eliminate that gasket that lasts a short time then cracks. I put my vent stacks back together with a thick bead of Trempro-635 around the pipe. It is an experiment but I am working on a permanant fix. If you go back with a gasket you should caulk around the flange above and below the gasket. The gasket will crack in a short period of time.
Perry
Old 10-18-2012, 09:37 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Here is the method Iíve used on the Tradewind stacks. Did the same thing on my í67 Globetrotter that uses a different type of cover.
Some may consider this blasphemy but I donít use Vulkem, Tempro or Sika Flex. I use Ultra-Blue Silicone Gasket maker. This has been used in the automotive service field for 20+ years. It was designed for aluminum blocks, pans, valve covers, ect. it is non-corosive, very flexible, has a wide temperature range, gap fills, sticks to almost everything and appears to last forever.
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_makers/auto_Permatex_Ultra_Blue_Multipurpose_RTV_Silicone _Gasket_Maker.htm
The 3 vent covers on the TW had the screens corroded or broken out, with dirt and leaves collecting inside and water leaking down into the closets and floor.
Just putting the screen down over the pipe wonít stop junk from collecting inside the cover. There may be a small weep hole at the lower edge of the casting. IMHO this is fairly worthless. I filed out a ľ inch grove at the bottom of the flange to drain out any water that gets in. I fit aluminum screen to the inside of the cover and secured it with the Ultra Blue and let it cure for a couple of days.
After cleaning the old sealer, gasket and crud from around the vent pipe I laid a generous bead of the sealer between the pipe and the shell and a dab around each screw hole. Then fit the gasket over the pipe. Then the cover went down on the gasket without any sealer. I secured the cap with new stainless screws.
My thought was since this stuff is pretty tenacious I donít want to wreck anything taking off the cover if the screen is damaged or the vent plugs up.
After this repair the GT hadnít leaked in the 5 years before I sold her and the TW is leak free after 3 seasons. As an aside, I have a "temporary" Ultra-Blue patch on a plastic wash tub at home thatís held for 18(?) years.
The purists may flame me for using a silicone but I canít argue with success,
Tom
Name:	TW Roof Vent.jpg
ID:	170763   Click image for larger version
Name:	TW Roof Vent 2.jpg
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 10-19-2012, 03:31 AM   #6
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Nice job. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 10-19-2012, 06:52 AM   #7
1982 34' Limited
Thanks everyone for the comments. I did use a new gasket, the old one was well past its best before date.
I like Tom's idea with the screen though, keep all the gunk outside and that will solve half the battle I think. I'll do mine this weekend and post some pics of how I make out!
