Old 08-13-2014, 08:31 AM   #1
1991 34' Limited
Meridian , Idaho
Vent Fans not dead, but dying
We live in a 1990 34' Limited with front and rear ceiling vents with fans that DID a marvelous job of circulating the air but both are slowly dying. They come to a stop and can be restarted with a nudge but eventually wind down again.
I have tested the electricity to both and it is fine. My best guess is they need cleaning but I see no way to do that without drilling out rivets etc..those suckers were not put in with any maintenance in mind. Any advice or links to manuals appreciated.
johnfreeman6 is offline   Reply With Quote
Old 08-13-2014, 08:34 AM   #2
richw46's Avatar
Lexington , Kentucky
Maybe the bearings just need some lube. Any way to get a little silicone or oil through one of those thin tubes to the bearings? It could be the motor brushes and that would require you to disassemble them. I'd try getting some oil to the bearings first and see if that helped
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-13-2014, 08:41 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by jfreeman62 View Post
..... Any advice or links to manuals appreciated.
My advice would be to replace them with Fantastic (Vent) Fans.
I replaced all of the original fans on both the '87 Classic Motor Home and the '78 Sovereign with great success. Fantastic Vent supplies a good replacement step by step manual if you tell them you are working on an AS. Also, request the rounded interior trim. The special AS trim fits the rounded dome of the AS.
Lots of "how to" for the AS vent replacement here on the Forums and on the internet.
Since you are living in the trailer, I would also suggest you get the "deluxe" version of the vent fans. The best ones are bi-directional, have thermostats, variable speeds, and are auto closing if it starts to rain. I have found a benefit for an outer cover over the vents also - just be sure that the outer vent is tall enough to let the Fantastic Vent automatic cover raise up far enough to allow proper air movement.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-13-2014, 09:17 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
You can replace the motor and the blade if you want to. I did. I ended up removing them though because i wanted reversable and variable speed fans. I put in Maxxair Deluxe fans that come with the crank up rain protector lid. They do a good job and dont stick way up off the roof when closed. Ive got the two stock fans, one with brand new motor and blade sitting in storage.
mayco is offline   Reply With Quote
Dying battery in a 1966 Trade Wind Ben in MT Batteries, Univolts, Converters & Inverters 7 10-03-2010 08:38 PM
fans or no fans goransons Refrigerators 8 12-31-2007 12:21 PM
Dying and going to heaven Alumunit Member Introductions 15 12-28-2007 04:18 PM
So, Are You Just DYING to get an Airstream??? fireflyinva Our Community 5 05-21-2004 08:34 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
