Old 06-08-2015, 10:33 PM   #1
1968 30' Sovereign
New Richmond , Wisconsin
Use of Butyl Putty tape
We're working on restoring a 1968 Sovereign, and I'm getting opinions from some DIY friends about the use of Butyl putty tape. I though I'd turn to this forum for some expert opinion about the use of butyl putty.
I need to replace the exterior stove vent, the rooftop refrigerator vent; the existing air conditioner shroud (I'm planning on keeping the working original air conditioner but the shroud has numerous pieces missing); and the two roof fans with Fantastic fans. On the first three, I'm being told that butyl putting tape is the way to go - even though only the refrigerator vent replacement is aluminum and the other two are fiberglass reproduction pieces.
Should I be using butyl putty tape to seat the first 3 pieces or should I be using Tempro 635 or Tempro 644 instead to "seat" and seal the vents and the shroud?
Thanks for any advice or insight you can give!
cheetah1 is offline   Reply With Quote
Old 06-09-2015, 12:05 AM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Have a look for Tintins sealants summary, He's got all the info you will need for what you can or should use where :-)
thesignlady is offline   Reply With Quote
Old 06-09-2015, 01:40 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Only butyl tape as a bedding seal if you ever intend to remove anything you are replacing. Using a polyurethane sealant like Trempro or SikaFlex under a vent will require significant labor if you ever want to remove it again (this stuff DOES happen).
Also, you might look into the Maxx Air fans instead of a Fantastic Vent. They are similar in price, have many more features and have integrated covers that allow for use in the rain WITHOUT those ugly bubble type additional fan covers.
I install the Maxx Air fans 10 to 1 over a Fantastic Vent. Another benefit is maintenance. If you ever have to replace a motor or circuit board, you simply remove 4 screws and the entire fan mechanism lifts off from the roof, leaving the mounting bezel sealed to the roof. It's a simple 10 minute change out!
Old 06-09-2015, 05:33 AM   #4
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Lew is %100 correct. I've been using butyl tape on my sailboats for many years on items such as stanchions and deck hardware. The ability to remove the bedded item at a later date is important to me. Beware, all Butyl tape is not the same. The crap that is sold to bed your topper, for example, is of poor quality and should not be used to bed/seal on an AS. Check out Compass Marines site to get the appropriate butyl tape. Love the stuff.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 06-09-2015, 05:44 AM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I'm about to change out the second Fantastic fan on my 25' with a MaxxAir fan. I did the first one year and also did it on my '07 20'. IMO they are much more versatile fans. One of the best features is that they will ventilate in the rain. I seat them in butyl tape and then seal screw heads and edges with sealer.
2012 Dodge Durango Hemi/AWD
Old 06-09-2015, 11:22 AM   #6
1968 26' Overlander
Portland , Oregon
Agree with Ron and others. Butyl is the way to go & "Bed It Butyl" is the stuff to buy. I have used different kinds on my sailboat and the "Bed It" is the way to go. Also check the Compass Marine blog on bedding hardware technique. The fundamentals are the same. Here is a link to the tape.
***Buy Bed-It Butyl Tape*** Photo Gallery by Compass Marine How To at pbase.com
AirstreamPDX is offline   Reply With Quote
Old 06-09-2015, 12:07 PM   #7
St Paul , MN
How difficult of a job would this be? Will Airstream install MaxxAir? Thanks for info on them - not ventilating in rain is my only complaint about FF. What other features do you like not on FF? We are fairly new to RV and had not heard about MaxxAir - website has lots of products - which model did you get?
Seemore2006 is offline   Reply With Quote
Old 06-09-2015, 12:35 PM   #8
Wayne&Sam's Avatar
Images: 21
The first one I had installed at Jackson Center- I had to supply the fan. That original vent didn't have a fan so I let them run electric to it.
On my 2014 I'm doing them myself. They both have electric already. The replacement is easy- the openings in the roof are the same size so you're not cutting metal. I don't think it took me two hours for the first one, and the was going very slowly and methodically.
Other things I like about the MaxxAir: Remote control, very low and quiet speeds,and it doesn't rattle in the wind.
Mine is the Deluxe Remote 7000K. That's a white cover. 7500K is a smoke cover.
Old 06-09-2015, 01:45 PM   #9
1994 34' Limited
colebrook , Connecticut
Does the MaxxAir have the same warranty as the Fantastic vent ?
My original Fantastic vent is 31 years old and i can get excellent over the phone troubleshooting and parts for no cost (only shipping).
i needed a new motor for a fantastic vent i installed in 2011. Motor was shipped for $15, had fan installed on motor, proper terminals on leads and included a new limit switch.
Hard to switch from a fan with this kind of service.
Mark
malett is offline   Reply With Quote
Old 06-09-2015, 02:15 PM   #10
Wayne&Sam's Avatar
Images: 21
Don't remember the warranty on FF, but MaxxAir is two years. As I recall FF was sold and new owners are not quite as forgiving on warranty items as the previous were.
Old 06-09-2015, 02:25 PM   #11
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Butyl is great when used right, as stated above if you ever plan on replacing it makes it easy. Problem on using it with weight pressing down is it's ability to staying soft allows it to squeeze out with pressure. Vertical mounted items apply pressure only with the mounting screws and you can watch it ooze out.
Old 06-09-2015, 03:07 PM   #12
lewster's Avatar
FF is now owned by Atwood, just as MaxxAir was purchased by RV Products (Suburban and Coleman)
FF no longer provides parts out of warranty and both have a 2 year new product warranty.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-09-2015, 03:11 PM   #13
1994 34' Limited
got fan motor last week, paperwork was from attwood, only paid shipping.
guess they screwed up ?
Old 06-09-2015, 04:27 PM   #14
1981 31' Excella II
New Market , Alabama
Butyl is probably the reason most SOB trailers die an early death. Eventually, the tape starts to gap and lets water in. I would use the polyurethane between two surfaces. Dispite all the polyurathane advocates on here, it will not last but a couple years in direct sunlight. If it is between two surfaces, then it will be ok. They best thing I have found for long term UV exposure is LEXEL but it stays gummy and will collect dirt. There is a tape sealant that you put over lap joints that works pretty well.
Perry
Correct method for using Butyl putty tape on window frames dcole Windows & Screens 2 03-15-2015 10:25 PM
What thickness butyl for vista view window. bmklawt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-29-2009 08:10 PM
butyl putty tape on the roof bacevedo Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 02-22-2009 05:09 PM
Source for pre-shimmed butyl tape pnb77 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2008 09:48 AM
Seeking advice on replacing butyl tape sealant on ridged aluminum SOB SilvrSausage Vintage Kin 0 09-22-2007 11:03 PM
