Old 12-08-2018, 12:29 PM   #1
Brett C.
Boiling Springs , Pennsylvania
Upgrade TV
Any recommendations on TV upgrades? I have a 2006 Safari that I would like a more dated television for. I live in Pennsylvania.
Brett C. is offline   Reply With Quote
Old 12-08-2018, 01:14 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Samsung 28” is about as big as you can go. Works great.
Old 12-08-2018, 01:19 PM   #3
aftermath's Avatar
Spokane , Washington
TV usually means Tow Vehicle. I checked in to listen to the typical fight when this comes up.
We have the same trailer, well not the actual same trailer but the same model, and year too. I replaced my television with a Samsung. The original was so old I couldn't get channels when they changed the delivery system.
I did look into a 12 volt system but after reading here that they had their shortcomings as well, I just got one out of a store. I upgraded to a larger one a few years back and have had zero trouble with it. I leave it out all winter too and it hasn't "frozen up" as some said it could. Any decent brand television that fits in your space will work. I would not go cheap though.
aftermath is offline   Reply With Quote
Old 12-08-2018, 01:23 PM   #4
kpm
2018 25' International
Mound , Minnesota
Buying a TV for an Airstream isn't much different from buying one for a house. It is worth checking out reviews on sites such as RTINGS and cnet.
We are personally fond of the smart TVs produced by Samsung. Add an Internet connection and you're ready to stream Netflix and Amazon Video.
kpm is offline   Reply With Quote
Old 12-08-2018, 01:53 PM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Upgrade TV
X2 for Samsung smart TV.
wulfraat is offline   Reply With Quote
Old 12-08-2018, 02:01 PM   #6
Mollysdad's Avatar
Originally Posted by Brett C. View Post
I would like a more dated television...
What is a "more dated" television?
Less modern? Certainly not a tube.
Other thoughts. Assuming it's mounted on a bulkhead (wall) measure how wide your space is. TV's are measured diagonally, and perhaps more important, the frames and the speaker location affect the horizontal measurement as much as the picture size.
All modern TV's are using the VESA standard mount, meaning it's pre-drilled for a certain hole spacing on the back to accommodate the mount. 100mm x 100mm, for example.
Go TV shopping with a tape measure.
Now for the real nitty gritty, after you decide on what you like, download the manual and see if it has inputs and outputs to accommodate your tech. It's really hard in the store because most TV's are mounted on the wall, and salespeople are not used to answering questions about connectivity.
All will have an HDMI or two. You may have a video camera you want to play on your TV.
Personally, I like an "audio out" either in analog (RCA plugs, 3.5mm mini) or digital (RCA or fiber) to connect to a soundbar, for example, since TV speakers are dinky today.
Old 12-08-2018, 02:32 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Samsung smart tv.
I installed a Samsung in my AS before they had the smart TV, so I just added a Roku streaming stick. It uses my internet (Verizon data). Not as good as a smart TV, but acceptable.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 12-08-2018, 02:39 PM   #8
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Hello Brett,
Just happened to see this is your first post and that you are literally just up the road from me.
Welcome to the forum. It's a good place to ask and share. It's good to have you with us.
Regarding your TV I agree with others. Buy what you would for your house and it should work well in your AS. Of course size does matter!
Best regards!
Hans627 is online now   Reply With Quote
Old 12-09-2018, 12:56 PM   #9
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I vote for the Samsung. And not made in China.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-10-2018, 07:55 AM   #10
Brett C.
Originally Posted by Hans627 View Post
Hello Brett,
Best regards!
Thanks, Bob. Is there a place locally that you would recommend to install a television in our Airstream?
Old 12-10-2018, 08:28 AM   #11
Hans627's Avatar
Hi Brett,
My buddy (who also has an AS) had his TV installed at Colonial AS in New Jersey. It was a TV replaced under warranty. Otherwise I don't know who might install a TV.
You might want to contact the AS service department in Jackson Center and ask them what model they are putting in the new units and if you could purchase the attachment bracket. The bracket should fit the new TV that way.
I hope that helps a bit!
Axle upgrade markdoane Axles 12 04-14-2004 06:42 PM
Fuel Injection Upgrade? Buck58 General Motorhome Topics 10 11-19-2003 04:47 PM
Amarillo Upgrade Package joshua32064 2003 Safari 5 09-28-2003 08:14 AM
Overdrive (ie; US Gear) VS trans upgrade ... Hayseed Mechanics Corner - Engines, Transmission & More... 24 07-17-2003 08:19 AM
Rear bed frame upgrade ViewRVs Airstream Motorhome Forums 3 05-10-2003 09:53 PM
