Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 05-28-2009, 01:03 PM   #1
Brow324's Avatar
2007 27' Safari FB SE
Scurry , Texas
Up On the Roof-tricks to avoid damage?
any ideas for getting on the roof to do some work on vent lids?
Step ladder or extension ladder? Good tricks to avoid dents and scratches on the sides and top?
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
Old 05-28-2009, 01:53 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Years ago I made a frame to support a platform across the top of my Airstream. Never used it yet but this is how it worked.
I cut 2 pieces of 3/4 plywood 8 ft long that would set between the awnings and the roof on each side and sit up high enough to support the platform across the top of the trailer. To hold those supports vertical I cut 4 pieces of plywood with 3/4 in slots, complementary slots were cut in the 8 ft boards, in them so they would fit down on the vertical boards at right angles and form an X for the platform. The weight of me on the platform would keep the vertical boards upright.
This makes an easy to assemble and store roof top platform.
I did this in case I had to remove the AC, but so far so good.
2004 Excursion 4x4
Old 05-28-2009, 02:08 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We just bought ours (used) last year. I asked the dealer about this and was told to make sure only to step on the rivet lines and above all, to stay completely off the end caps. They are very easily dented.
I did this last winter when we were in California to check all the caulking up on top and it seemed fine.
I took one of those folding extension ladders with me on the trip and just used it as a straight ladder leaning up against the rolled up awning to access the roof.
That too seemed fine and caused no damage.
I plan to go up top at least a couple of times a year to chech teh condition of the caulking.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-28-2009, 02:11 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I use foam plumbing insulation on my extension ladder for pads like this:Product Information Error Page.
Don't ask me why it says Error Page, the link works.
The sticky part of the "Self-Seal" keeps it in place and it lasts a long time.
Vaughan
Old 05-28-2009, 03:17 PM   #5
woodenicol's Avatar
1988 29' Excella
Hammond , New York
I recently replaced the shroud on the ai conditioner. I had a small tractor that I had borrowed for another project. I put one guy in the bucket of the tractor and leaned a fiberglass 8' stepladder against the awning on the other side for me. I did notice how strong the ribs were, although never had to walk on the roof.
woodenicol is offline   Reply With Quote
Old 05-28-2009, 06:13 PM   #6
1972 Travelux Princess 25
Cobourg , Ontario
Take off your longhorn cowboy belt buckle before you lean against the trailer. Also rivetted jeans with copper buttons.
Best idea, wear sweat pants and sweat shirt, and make sure the pockets are empty.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Stupid Awning Tricks OrangeKid 2007 Safari SE 21 03-26-2007 07:11 AM
A smart way to avoid flood damage HHP Off Topic Forum 16 07-24-2006 08:41 AM
Roof damage from tree JOHN L Roof 15 06-19-2004 12:02 PM
Stupid human tricks, part 2 74Argosy24MH Off Topic Forum 9 12-22-2002 01:14 PM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 02:08 PM
