Old 05-24-2015, 02:27 PM   #1
camarobob's Avatar
2004 25' Safari
So Utah , USA
Unusable Jack Points on 04 Safari
My 04, 25' Safari has two indicated jacking points located on either side of the underbelly toward the rear of the trailer. The owners manual states that if its necessary to jack up the trailer to only jack at these points. However both of the jack points are unusable. The jack point on the street side is blocked by the grey water drain line and the jack point on the curb side has a gas line running across it. (ppp)
Has anyone else encountered this problem?
I realize that ramps can be used to raise a wheel but If it becomes necessary to jack up the trailer what is a good/safe alternative jack point ?
camarobob is offline   Reply With Quote
Old 05-24-2015, 03:41 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I generally jack up an Airstream on the axle reinforcing plate. It is the part that comes down from the frame, that the axles bolt to.
Old 05-24-2015, 03:58 PM   #3
1974 Argosy 20
Kooskia , Idaho
Yes, jacking at the plate as overland63 mentions is the best and most secure way I know. I was on the Alaskan highway once and had a flat on my single axle trailer. A passing truck blew it off the jack which was positioned at the designated jack point. The jack then punched a hole through the belly pan, and floor. It was a bottle jack. Never again will I use the designated jack points, too easy to slip off them.
2015 50A Power Cord Stiff and Near Unusable 2012FB 2009-2015 Flying Cloud 35 01-09-2015 04:34 PM
Jack Points on 21 ft. 1995 Sovereign? johnobuttons Jacks, Stabilizers, Lifting and Leveling 4 07-31-2010 03:26 PM
Jack Points "77" Argosy 24 BigMike Jacks, Stabilizers, Lifting and Leveling 3 08-02-2008 05:35 PM
Jack points and Duratorque axles ray matthews Axles 3 03-06-2005 05:26 PM
Where are the jack points? barbwire All Argosy Trailers 6 11-11-2002 09:52 AM
