Old 07-03-2016, 11:17 AM   #1
TWC
2015 25' International
Georgetown , Ontario
Unreliable Bathroom vent fan
I have a 2007 23' Safari SE with the round bathroom vent in the ceiling. The fan is intermittent and I suspect a faulty switch. Can the switch be replaced without removing the entire unit? If not, what is the best solution?
TWC is offline   Reply With Quote
Old 07-03-2016, 12:26 PM   #2
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
Yes the switch can be replaced without removing the entire vent. You will need to remove the push up handle and the screen. I bought a better quality 12 volt DC switch with wire leads at an Ace Hardware. Be careful when cutting the existing wires as the hot wire is very short!
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Fan-Tastic vent fan cover C FORD Roof 11 12-09-2015 12:47 PM
Fan-tastic a good replacement for a vintage fan vent? Globie64 Roof 1 08-23-2015 06:04 AM
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? stc cigar Airstream Classifieds 0 02-19-2014 08:45 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Bathroom vent fan - 6 inch round Lee Davis Roof Vents, Skylights & Fans 8 08-23-2005 09:32 AM
