Old 01-17-2016, 10:41 AM   #1
Fort Collins , Colorado
Undersink Delta Water Filter - 2007 Classic
I am looking at a 2007 27FB Classic AS trailer, however, we discovered that the trailer was not properly winterized and the Delta water filter unit has been damaged. How difficult and expensive is it to replace the unit with another water filter unit (different brand?}as it appears that this particular unit is no longer manufactured? Thank you. Bill
bothwbp is offline   Reply With Quote
Old 01-20-2016, 10:06 AM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I've never seen one, but it can't be too hard; it's just plumbing. I'd ask first why you want a water filter; unless you went with a reverse osmosis unit, it pretty much just takes out the big chunks anyway. Why not just use a filter on the incoming hose connection and thus cover the bathroom sink as well?
Anyone know the size of the undersink tambour in a 73 29' Mid bath? pneumatair Cabinets, Counter Tops & Furnishings 2 06-24-2010 02:20 PM
how to remove moen undersink water filter on 2010 bambi dsrtgrls Water Heaters, Filters & Pumps 5 12-06-2009 07:38 AM
Delta Under Sink Water Filter evanskl Water Heaters, Filters & Pumps 0 05-22-2009 11:07 AM
Tambour Undersink Door LRPorter All Argosy Trailers 22 05-14-2009 07:56 PM
Delta Faucet instead of the old Moen okay? 73ANDY Sinks, Showers & Toilets 7 05-01-2003 06:21 PM
