Old 03-20-2015, 01:09 PM   #1
Durango , Colorado
Umbilical Cord Plug Maintenance?
Does anyone have tips on the proper maintenance and products to use on the umbilical plug that connects the TV to the trailer?
My plug is getting a lot of dirt and moisture in the end and I am not sure what the proper cleaning procedure is or what electrical neutral jelly to use for lube.
Any tips or suggestions would be appreciated.
RVDreamer is offline   Reply With Quote
Old 03-20-2015, 01:41 PM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I use this for the plug end & contacts, male & female.
Comes in handy for a lot of things, stays in the AS tool kit.
Also........route the cord thru a D-ring on the ball lock and secure the plug with a zip-tie and bad things won't happen.
Old 03-20-2015, 01:53 PM   #3
1974 Argosy 20
Kooskia , Idaho
I use a spray contact cleaner, I think it is CC brand, often available at full line ACE type hardware stores. Spray both the plug and TV socket and push it in and pull it out several times to clean things out.
That said, the umbilical cord plug and TV socket take a lot of abuse and do corrode and get just worn out. Replacement is often a good thing after a few years of service. When you look for new plugs and sockets, look inside to see that the contacts are brass colored. There are a large number of silver colored plated steel contacts showing up at the RV parts stores and places like Wal Mart these days. The plating is not silver, just that color, and the fittings are mostly JUNK. You may have to look a bit for brass ones but they are well worth the time to get good ones.
Old 03-20-2015, 08:39 PM   #4
Durango , Colorado
Thank you for the responses.
What is everybody using for the electrical neutral jelly that was in the plug to keep moisture out and help guard against corrosion?
Old 03-20-2015, 08:44 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Clean well, lube up.. Always great for recreational activities.
I then hang the "end" under the propane bottles. Keeps out of rain and dirt.
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-20-2015, 09:17 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I use a 100% silicone dielectric grease to flood the plug after cleaning it out with an aerosol can spray (TechSpray's G3 contact cleaner). I clean the plug & socket twice a year during use; a cleaning/grease application is done before storage over winter.
SeeMore is offline   Reply With Quote
Old 03-20-2015, 09:31 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If it comes to a point where the plug or socket need replacing, consider changing to the seven pin commercial (round pin) plug and socket. These will last for years without problems, and as a bonus the cord itself can be replaced in any truckstop or Napa type store nationwide.
http://www.etrailer.com/question-27196.html
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 03-20-2015, 09:34 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Wiring Diagram for 7-Way Round Pin Trailer and Vehicle Side Connectors | etrailer.com
You "can" install the "vehicle" side on the AS then cable up an umbilical to go between the AS and TV. Remove the cable when storing.
Old 03-21-2015, 10:52 AM   #9
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Based on personal experience Mr. Cross' advice re securing the plug to the TV with something like a zip tie is the most important advice....having lost this connection one time on a steep downhill grade in PA...thus having no camper brakes to help...was an experience I never want to repeat. Mr. Cross's advice can save your AS (and more). Safe travels. jon
B00merang is offline   Reply With Quote
Old 03-21-2015, 11:32 AM   #10
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
7 pin cord cover
I just ordered a cover for the 7 pin cord, when not in use.
From Fastway Trailer Products. $5.95
Name:	7 pin cover.jpg
RAH is offline   Reply With Quote
Old 03-21-2015, 12:23 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't store with the connector hanging in a way it can capture water. That could short the wires and the 12v+ line causing issues like battery drain.
Old 03-21-2015, 10:24 PM   #12
1974 Argosy 20
Kooskia , Idaho
That cover will hold the water in the plug very well. I want mine to drain.
Umbilical Cord Replacement watt1968 Electrical - Systems, Generators, Batteries & Solar 5 06-13-2009 06:39 AM
Umbilical cord/battery draw davidz71 Electrical - Systems, Generators, Batteries & Solar 5 06-16-2008 10:33 PM
Install new umbilical cord beginner5 Electrical - Systems, Generators, Batteries & Solar 7 07-09-2007 09:02 PM
Umbilical cord mickleton Electrical - Systems, Generators, Batteries & Solar 4 07-07-2007 10:25 AM
old stlye umbilical cord mrbeanpa Lights - Interior & Exterior 4 03-15-2006 11:37 AM
