04-19-2014, 04:41 PM
#21
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I used EPDM roofing material for the gasket with just a small bit of sealant around base of the metal piece AND under the gasket. Belt and suspenders if you will. I have access to a whole gamut of single ply roofing materials, next go around I might try one of the PVC sheet goods, some are warranted for over 30 years.
Aaron
WBCCI #XXXX AIR #2495
04-20-2014, 09:06 AM
#22
1977 31' Sovereign
Black Diamond
With a massive downpour yesterday the leak was still there. I'm going to focus back on the stove vent. This time I will take it apart and reseal. The hard part is removing the piece that pushes the flap open.
Sent from my SCH-I535 using Airstream Forums mobile app
04-20-2014, 04:29 PM
#23
1981 31' Excella II
New Market
, Alabama
Here was my temporary fix. Not having the leak was worth more than having a vent fan. You can always change you mind and add back leaks later if you removed too many.
Perry
04-22-2014, 10:42 AM
#24
1977 31' Sovereign
Black Diamond
Vent sealed, Vent pipe sealed, still leaking at the same rate. Will work on taking air conditioner cover apart next. If it still leaks then I give up and invest in more buckets
04-22-2014, 10:51 AM
#25
1981 31' Excella II
New Market
, Alabama
Look at rivets on both sides of the door.
Perry
04-22-2014, 12:48 PM
#26
1977 31' Sovereign
Black Diamond
Perry
Which door?
04-22-2014, 03:38 PM
#27
1981 31' Excella II
New Market
, Alabama
The main door for people.
Sent from my SAMSUNG-SGH-I747 using Airstream Forums mobile app
04-22-2014, 09:12 PM
#28
1977 31' Sovereign
Black Diamond
It's not leaking at the entrance door. If you look at the picture I posted at first, it's right over the stove which led me to think it to be the stove vent, grey water vent pipe, or air conditioner. These three things line up right above this area.
I'm getting an air conditioner cover tomorrow and see if the leak stops. Hopefully this should tell me if it's the AC or not.
04-23-2014, 06:07 AM
#29
1981 31' Excella II
New Market
, Alabama
I would expect that if it was an AC problem that you would also be getting leakage from the vent where the AC is installed. Also the way Airstreams are made you can have a leak 6 ft away from where you think it is coming from. Your leak could be coming from the second roof vent for the toilet as well. Is yours center bath or rear bath?
Perry
04-23-2014, 06:09 AM
#30
1981 31' Excella II
New Market
, Alabama
Another place folks screw up is that little light housing over the door. It does not need any caulk as long as the screw heads are sealed and the door frame area is sealed.
Perry
Originally Posted by wahoonc
I think you may have covered the weep vents in the bottom of the metal cap there... Gotta have somewhere for the water that gets in between the stack and the cover to go.
Aaron
