Old 04-23-2014, 06:07 AM   #29
1981 31' Excella II
New Market , Alabama
I would expect that if it was an AC problem that you would also be getting leakage from the vent where the AC is installed. Also the way Airstreams are made you can have a leak 6 ft away from where you think it is coming from. Your leak could be coming from the second roof vent for the toilet as well. Is yours center bath or rear bath?
Perry
Old 04-23-2014, 06:09 AM   #30
1981 31' Excella II
Another place folks screw up is that little light housing over the door. It does not need any caulk as long as the screw heads are sealed and the door frame area is sealed.
Perry
Originally Posted by wahoonc View Post
I think you may have covered the weep vents in the bottom of the metal cap there... Gotta have somewhere for the water that gets in between the stack and the cover to go.
Aaron
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Water leak James Schmidt 1993 Excella 1000 11 02-02-2004 07:54 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
