Old 04-18-2014, 06:20 PM   #15
1981 31' Excella II
New Market , Alabama
The gasket is crap Andy. One made of silicone would be better because it won't rot. Viton might be ok as well. This would work. The best solution would be to weld a top hat shaped pipe nipple on top of the Tee-Pee that fits down inside the vent pipe. Then use caulk to seal the Tee-Pee to the roof.
https://www.mcmaster.com/#5787t33/=rlh7cg
Perry
Old 04-18-2014, 08:06 PM   #16
Perry
Perry.
I totally agree with you, but the above photo clearly shows that the gasket did in fact seal the base of the cover so that it did not leak as well.
That being the case, slopping a bunch of sealer around the base of the cover, is not necessary.
Old 04-18-2014, 08:44 PM   #17
mariusg78's Avatar
1977 31' Sovereign
Covington , Washington
Images: 21
Replaced the gasket today. Will update and see if it stops the leak. I think it's supposed to rain this weekend, surprise surprise. Thanks for all the great tips!
Sent from my SCH-I535 using Airstream Forums mobile app
mariusg78 is offline   Reply With Quote
Old 04-18-2014, 09:41 PM   #18
1981 31' Excella II
You could be right about the gasket sealing without the caulk around it. I would consider getting some of the silicone material and try that. You could corner the market on it. Your minions could punch a hole in that flat stock and cut it to the correct shape. They use Silicone and Viton on the space station. We did loose a shuttle to the Viton O-rings though.
Perry
Originally Posted by Inland RV Center, In View Post
Perry.
Old 04-19-2014, 03:10 PM   #19
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
VTS has a fully covered vent stack that does not have this problem. I just put some Trempro-635 around that vent pipe and put the Tee-Pee back on and it is still leak free after 2 yrs. I will probably modify the Tee-Pee by putting some sort of top hat on it and then the inner gasket does not matter.
Also it could still be your stove vent. Mine had a crappy flap door that would sometimes leak and sometimes not leak. The vents with the scoop on the outside don't have this problem. I cpvered the vent with a solid plate till I get a chance to make a scoop for mine.
Perry
What are you making all this with? Welding your own metals?
GAStreamin is offline   Reply With Quote
Old 04-19-2014, 03:40 PM   #20
1981 31' Excella II
I have a network of friends that help me make stuff. I can do a fair amount myself. Local welding shops can weld just about anything. Lack of time is my biggest problem. My job gives me access to resources most folks don't have.
Perry
Old 04-19-2014, 04:41 PM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I used EPDM roofing material for the gasket with just a small bit of sealant around base of the metal piece AND under the gasket. Belt and suspenders if you will. I have access to a whole gamut of single ply roofing materials, next go around I might try one of the PVC sheet goods, some are warranted for over 30 years.
Aaron
WBCCI #XXXX AIR #2495
Old 04-20-2014, 09:06 AM   #22
mariusg78's Avatar
1977 31' Sovereign
Images: 21
With a massive downpour yesterday the leak was still there. I'm going to focus back on the stove vent. This time I will take it apart and reseal. The hard part is removing the piece that pushes the flap open.
Old 04-20-2014, 04:29 PM   #23
1981 31' Excella II
Here was my temporary fix. Not having the leak was worth more than having a vent fan. You can always change you mind and add back leaks later if you removed too many.
Perry
Old 04-22-2014, 10:42 AM   #24
mariusg78's Avatar
1977 31' Sovereign
Images: 21
Vent sealed, Vent pipe sealed, still leaking at the same rate. Will work on taking air conditioner cover apart next. If it still leaks then I give up and invest in more buckets
Old 04-22-2014, 10:51 AM   #25
1981 31' Excella II
Look at rivets on both sides of the door.
Perry
Old 04-22-2014, 12:48 PM   #26
mariusg78's Avatar
1977 31' Sovereign
Images: 21
Perry
Which door?
Old 04-22-2014, 03:38 PM   #27
1981 31' Excella II
The main door for people.
Sent from my SAMSUNG-SGH-I747 using Airstream Forums mobile app
Old 04-22-2014, 09:12 PM   #28
mariusg78's Avatar
1977 31' Sovereign
Images: 21
It's not leaking at the entrance door. If you look at the picture I posted at first, it's right over the stove which led me to think it to be the stove vent, grey water vent pipe, or air conditioner. These three things line up right above this area.
I'm getting an air conditioner cover tomorrow and see if the leak stops. Hopefully this should tell me if it's the AC or not.
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Water leak James Schmidt 1993 Excella 1000 11 02-02-2004 07:54 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
