Old 11-29-2014, 04:17 PM   #1
1974 27' Overlander
North Granby , Connecticut
Trying to find out what year it is.
Hi All
This is now at my home my problem is that the Vin number is as follows
I 27 T 9 J 296 now talking with the technician at air stream he says it is a 1969 by the ser. number but everything i found on line concurs with what he says. He then ask if it had two hings or a single hinge i told him that it had two hinges. The info that i got from all of you looks more like it is a 1979 with flip handles on the door and round corners on the windows. Now here is the kicker. I just got the Owners manual and it says it is a 1974. Who is right???
Big G
Big G is offline   Reply With Quote
Old 11-29-2014, 06:09 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Have a look here
Vintage Airstream Photo Archives - Vintage Airstream
Looks to me that the 9 in your vin stands for 1979
There's broken picture link in your post, if you need help there's instructions in post 7 here;
http://www.airforums.com/forums/f138...ics-44928.html
reinergirl is offline   Reply With Quote
Old 11-29-2014, 06:34 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If it is a 69 it will have square corners on the rear window, square corners on the outer bottom of the wing windows in front and a protruding type door handle. The water tank will be in the front under the couch with the fill on the front of the trailer. If it is 1970 or later the door handle will be recessed and all window corners round.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
need to find out year model on Argosy to restore april2014 Vintage Kin 2 04-09-2014 04:00 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Trying to find a lens cover for a 2007 Bambi gqmmom 2005 and newer - Bambi all models 2 07-11-2010 09:31 AM
Trying to find shower curtain for '93 Excella ghilliedhu1 1990 - 1993 Excella 3 09-05-2009 02:57 AM
Trying to find aluminum caulk Bluto Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 05-28-2009 09:09 PM
