Old 07-18-2015, 04:48 PM   #1
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Tread wear. Easy access.
Ever lay there in the trailer and wonder about your tread wear?
Install an easy viewing port. All you need to do is blow a tire and turn on the steel cable reinforced rubber tire weed eater.
Name:	ImageUploadedByAirstream Forums1437259612.477589.jpg
Name:	ImageUploadedByAirstream Forums1437259631.245757.jpg
FC7039 is offline   Reply With Quote
Old 07-18-2015, 05:18 PM   #2
1977 25' Tradewind
Florence , South Carolina
Ouch! That's not good.
ajcannon is offline   Reply With Quote
Old 07-18-2015, 05:34 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Now that is a solution to a problem I never hope to have.
MICHAEL
Old 07-18-2015, 05:48 PM   #4
K.C. , Missouri
"flow through" ventilation.
gmw photos is offline   Reply With Quote
Old 07-18-2015, 10:52 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Duct tape.
Sorry for the trouble. What tires, age, inflation, trailer load, speed?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-19-2015, 03:37 AM   #6
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
So sad to hear / see that about your Vintage AS. Our TPMS has saved our bacon four times so far. Hope repairs can be made, and good as new, or better.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-19-2015, 05:31 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
On the bright side, you don't have the miles of plumbing and wiring that would have been shredded if you had a newer trailer.
If you have a single axle trailer, I saw a clever replacement once that involved a galvanized steel washtub. It just happened to have the right curvature, and the owner would never again have a destroyed wheelwell.
Mismatched tires/tread wear Smoky Tires 2 02-21-2012 07:37 PM
Goodyear Marathon tread separation ... and our solution RossFam05BH Tires 226 06-26-2010 10:27 AM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
Underside damage truck tire tread - 2004 Classic gklott 2001 - 2005 Classic 1 06-11-2004 08:15 PM
