Old 04-01-2015, 04:20 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
No pics!
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-01-2015, 04:50 PM   #2
Concord , California
Hope this works . . .
https://drive.google.com/file/d/0B_4...ew?usp=sharing
ClaySimmons is offline   Reply With Quote
Old 04-01-2015, 09:29 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Clay,
there is some serious rust going on i would clean up the tongue and repaint. the separation might just be where caulking fell out. It might be a bigger problem...if the frame is separating from the front shell or floor.
Serious investigation may save you a bigger problem... fix it..
Channing
WBCCI# 30676
Old 04-02-2015, 05:58 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
If what I think I am looking at is correct cwf hit it. Looks to me like you've got some skin separation from the frame and that the frame appears to have some surface rust. IF this is what you have, I would brush and remove the rust, repaint the frame area and then re-caulk the skin to the frame. Tempro 635 will work, it is an aluminum colored caulk that even when dried stays flexible.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-02-2015, 07:22 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Yes, there is some surface rust on the frame. The separation is from where the center wrap piece curls under into the belly pan. Like the banana wraps on the corners. What happened is the vulkem has shrunk, giving the gap. Pick out the old vulkem, sand the area and apply new vulkem. If left unchecked, this is a point of water entry into the belly pan.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-02-2015, 07:58 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
A prior post seems to be missing? In #1 CWF seems to be responding to a post that is no longer there. What's going on?
I do not see any structural issue in you photos. If you are trying to show differential movement between the A frame and skin, it looks normal to me. The caulk needs replacing. The joint between skin and frame on both my 25' and 34' looked similar until recently. If there is other evidence of separation, these pictures do not show it.
I would steel brushed the A frame to remove as much rust as possible. Then I would painted the A frame with Rustolium Rust Reformer. Then paint with a finish coat.
Re-paint and re-caulk! Good for a few more years
Alan
Old 04-02-2015, 01:47 PM   #7
Thanks, all. A W Warn, you are correct, the mods deleted my original post for some reason, which makes this whole thread sort of confusing. Some of you picked up on what I was inquiring about just from the photos. My question was whether this was a structural issue or a caulk issue. The gap on the curbside looked bigger than the roadside and I was worried that this might be a weld / structural separation. Sounds like it's probably just sealant. I didn't ask anything about the rust but obviously this needs to be dealt with. BTW, this is not my trailer. I've been looking to make an offer on it. I'm new here and am looking for my first AS for my family. Thanks again for your comments. -Clay
How to...trailer/ truck connection AIR-Quarius Tow Vehicles 14 02-27-2012 07:46 AM
Trailer / tow vehicle connection upgrade polarlyse Lights - Interior & Exterior 3 08-31-2009 09:58 AM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
30 amp cord connection in trailer side davidz71 Electrical - Systems, Generators, Batteries & Solar 25 01-31-2006 10:10 AM
Pinout for '01 F250 trailer connection bilby05 Electrical - Systems, Generators, Batteries & Solar 3 12-23-2005 08:40 PM
