Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-07-2008, 05:04 PM   #1
Southwick , Massachusetts
Trailer hunt questions
Not sure what the right forum would be for these so please direct me to the "right" one if there is one.
I'm starting to look around at used/vintage trailers for purchase and have noticed many of them are situated in trailer parks in vacation areas. Which to me means they have probably not moved in a while. Many of these areas are at the shore, as in the Maine shore. I noticed while reading that folks tend to look for trailers that have not been by the water and I'm wondering what would be considered "by the water", like within a mile, 5 miles, 30 miles? and what would the repercussions be to a trailer that spent some years there? I can't imagine the salt would be good for them but how bad is it?
Also would there be anything special I should check on trailers that have been sitting in a park besides tires and brakes?
Padlin00 is offline   Reply With Quote
Old 08-07-2008, 05:09 PM   #2
Retired.
. , At Large
It's a fine looking can of worms you've opened...
If the trailer was parked by the ocean, you will likely see a lot of corrosion on the skin, if parked by a lake or stream the corrosion would be underneath.
Trailers that are parked for extended periods get many of the same ailments as cars and trucks that are parked for long times. Water systems can (and probably will) leak, axles will take a permanent "set", and be pretty much frozen in place. As soon as you tow it, all the seams will shift, and many will start leaking.
Old 08-07-2008, 05:39 PM   #3
Thanks for the info, I think. What is a shifted seam? You mean around windows and doors? or between the skin panels? or both?
What would make the water systems leak, freezing?
Old 08-07-2008, 06:21 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Padlin... Shifting seams would mean movement or shifting at the seems between aluminum panels... Leaking plumbing could be caused by freezing or sitting there all dried out...much depends on the climate and conditions under which the unit has been sitting... In general, just sitting there for years is a bad thing...and if it's vacant and not used, that's even worse, as things that just sit tend to deteriorate faster than when they are in use...it's that old "use it or lose it" thing.
Here's a link to a subform that will gve you some general things to consider when you are looking for a used unit: http://www.airforums.com/forums/f353/ And there are other subforms that deal with specific systems and issues...clink on "forum listings" in the left column of your screen...that will take you to a list of subforums... Poke around in there and you will learn a lot about what to look for and what to do about certain things... and of course, you can ask questions, too! That's allowed!
Good luck, and we hope to see you down the orad in your own Airsteam soon!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Starting up trailer questions pompaneaux Electrical - Systems, Generators, Batteries & Solar 24 06-10-2010 12:08 PM
On the hunt! geneflorida Member Introductions 1 06-11-2006 05:56 PM
The Agony Of The Hunt therealtoddster Our Community 5 08-04-2005 06:56 AM
Trailer Questions Blue Airstream Trailer Forums 11 01-29-2004 08:39 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
