Old 12-30-2015, 09:19 AM   #1
2016 27' International
Montreal , Quebec
Torque wrench recommendation needed
As I prepare to receive my AS in May I realise I will need tools that I do not have. One of them is a torque wrench. When choosing one what should I be looking for. Do they all offer more or less the same level of precision +/ - 4% or are some models more precise and does that even make a difference. Should I opt for a model with a range that covers the need of the AS and TV or is there any advantage to have one with a larger range. Pass those general considerations do you have a specific model to recommand .
Papa smurf is offline   Reply With Quote
Old 12-30-2015, 09:37 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Depends what you'll use it for. If it's just for lug nuts any torque wrench will do. If you're going to rebuild engines, then you'll need a precision wrench.
Generally things measure more accurately near the middle of their range. So I wouldn't get one that means you'll usually use it at either extreme of its range.
2012 Dodge Durango Hemi/AWD
Old 12-30-2015, 09:50 AM   #3
Images: 59
Don't spend more than $80 US or less than $40 US.
Old 12-30-2015, 10:25 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Don't forget that torque wrenches come in different sizes as well, just like sockets. You may only need a 1/2" drive, or you may need multiple drive sizes.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-30-2015, 10:31 AM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I have one of these that I use for torquing lug nuts on our Avion. It'll go up to 150 ft/lbs. Not good for torquing the hitch receiver head.
Sears.com
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-30-2015, 10:38 AM   #6
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
For lug nuts a Sears 1/2 inch wrench is fine. Avoid the temptation to buy one from Harbor Junk. Don't make the mistake many do by setting the wrench to the desired torque and leaving it there. When done, always set the wrench to its lowest setting. Leaving it at a high setting distorts the tension spring over time degrading its accuracy.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 12-30-2015, 10:39 AM   #7
2016 30' Flying Cloud
Oviedo , Florida
For lug nuts and smaller hitch hardware, the 1/2" model at Harbor Freight is just fine. For larger hitch fasteners, Home Depot sells a Husky brand 1/2" that goes up to 250 ft-lbs. Of course it will also work fine for wheels - it's just long and somewhat more expensive than the Harbor Freight one.
For what you are going to use it for, don't spend the money on the Snap-On, Matco, etc stuff.
An important tip to prolong the life and accuracy of any torque wrench is to back off the tension setting all the way when it is being stored. Don't put it away with the dial set to 110 ft-lbs.
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 12-30-2015, 10:40 AM   #8
Oviedo , Florida
The Harbor Freight one has tested pretty well, and comparing it to my more expensive wrenches show it isn't as far off as you might think.
Keith & Barb
Old 12-30-2015, 10:45 AM   #9
2016 30' International
Boerne , Texas
I have always had pretty good luck buying one off tools at pawn shops. The last torque wrench I bought came from one at a very good price. I couldn't tell the difference between the one I bought and a new one condition wise, it came with a case and the calibration certification. After I bought it, I checked it against a wrench that a quality tire shop uses and it was spot on.
akjam is offline   Reply With Quote
Old 12-30-2015, 10:51 AM   #10
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
Torque Wrench
You'll need a 1/2 inch torque wrench for lug nuts, on trailer & truck. I bought one at Harbor Freight, for $20 less 20% off with one of their coupons, & haven't had any problems with it (although I have had problems with more complicated Harbor Freight tools). You'll likely also need a 1/2 inch extension bar, preferably around a foot long, also inexpensive at Harbor Freight. I share others' displeasures with Harbor Freight items, although it's hard to mess up simple tools like wrenches, sockets, etc., and Harbor Freight has quite a supply of them at ridiculously low prices.
Rgentum is offline   Reply With Quote
Old 12-30-2015, 11:08 AM   #11
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Name:	ImageUploadedByAirstream Forums1451498609.380993.jpg
I have acquired a few good ones over the years.
1/2" drive 250 ft lbs
1/2" drive 250 ft lbs w\ gyros for "torque to angle"
1/2" drive 100 ft lbs
3/8" dive 250 inch pounds...
However, if I was just working on a trailer, i would buy a cheapie.
Brevi tempore!
Old 12-30-2015, 11:15 AM   #12
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Do I really need a torque wrench? I thought about it this year when I switched to the 16" Sendels/Michelins, but ended up using a regular tire iron. I do check the lugnut tightness a number of times each trip, however. jon
B00merang is offline   Reply With Quote
Old 12-30-2015, 11:18 AM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Fwiw, even though I have a multitude of torque wrenches, I never torque my lug nuts. I know what feels right.
Those who don't know what right feels like should use a torque wrench.
Brevi tempore!
Old 12-30-2015, 11:20 AM   #14
2018 33' Classic
Newport , Pennsylvania
Snap-On
Earl
EarlM is offline   Reply With Quote
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 06:15 PM
Torque Wrench by Husky Devoman General Repair Forum 3 01-10-2016 06:51 PM
Torque Wrench..Which one to use. jomondnv General Repair Forum 38 03-19-2013 06:49 AM
Torque specs needed ASAP - Argosy motorhome bkahler Mechanics Corner - Engines, Transmission & More... 2 10-21-2008 02:08 PM
$28.99 for a torque wrench... did I was my $ Kistler Our Community 3 03-11-2004 06:27 PM
