Old 12-14-2019, 11:46 PM   #1
2016 16' Sport
Miami , Florida
Torque wrench
If you were going to get a 1/2 drive torque wrench for Christmas which one would you want. It’s only use would be for the Airstreams lugnuts.
Shiny16 is offline   Reply With Quote
Old 12-14-2019, 11:52 PM   #2
2007 22' International CCD
Torque wrench
One that goes up to 150 foot-pounds. Craftsman, Harbor Freight, darn near anyone make decent click-type torque wrenches.
Just be sure to slack it off to 30 foot-pounds or less when not in use to preserve the spring and calibration.
Old 12-14-2019, 11:56 PM   #3
2016 16' Sport
Miami , Florida
Old 12-15-2019, 04:19 AM   #4
brokeboater's Avatar
2003 25' Safari
High Springs , Florida
For lug nuts just about any will do. I will say pick one with the numbers stamped in metal rather than plastic. I find eventually the plastic ones become unreadable. I inherited a Husky 1/2" 50-250# with my last Airstream purchase and it's darned nice. $50.
“While you live, shine / Have no grief at all / Life exists only for a short while / And time demands its toll.”
brokeboater is offline   Reply With Quote
Old 12-15-2019, 05:16 AM   #5
Kensington , Maryland
Precision Instruments 1/2" 40-250 ft-lbs. Split-Beam Torque Wrench C3FR250F
I've had one of the above for two years. You do not have to return the wrench to zero.
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 12-15-2019, 05:34 AM   #6
2003 25' Safari
Originally Posted by Too tall View Post
C3FR250F
Seem a bit of an overkill for a dedicated trailer lug nut torque wrench.
Old 12-15-2019, 06:21 AM   #7
2019 30' Classic
Charlotte , North Carolina
A long one. For some reason they make shorter ones that have high torque. The longer the better I say. And one with a bottle opener on the end for when you are done.
LilPeanut is offline   Reply With Quote
Old 12-15-2019, 07:38 AM   #8
2018 27' Globetrotter
Elbert , CO
Harbor Freight - but wait until they go on sale or have one of their "20% Off Anything" coupons. They are my source for any tool that has to be "good enough" but won't see heavy use. Their sale prices are low enough that I have been able to afford one that is primarily used for lug nuts and one that goes up to 300 ft-lbs that is solely for adjusting/checking the hitch.
djb75 is offline   Reply With Quote
Old 12-15-2019, 09:33 AM   #9
Mollysdad's Avatar
Mine came from Harbor Freight.
I'm too lazy, and it's too hard to read to slack off every time, so it will just stay at 100.
Someday, I'll splurge for the digital Harbor Freight torque wrench.
And while you're at HF, get a breaker bar also, don't use a torque wrench to loosen nuts.
BTW, using a torque wrench AT ALL on lug nuts was a novelty until I joined this site. Most tire shops use an air gun to tighten lug nuts, "Bbrrrrp" Done.
Mollysdad is online now   Reply With Quote
Old 12-15-2019, 10:12 AM   #10
We use it for pickup softball games too. Dual purpose.
Old 12-15-2019, 10:23 AM   #11
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
It won't take long before it is no longer tightening to 100 lb/ft if you leave it under tension.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 12-15-2019, 10:27 AM   #12
2003 25' Safari
Well... all right then.
Old 12-15-2019, 10:38 AM   #13
jcl
Vancouver , British Columbia
A traditional beam type, not a split beam. Dual calibration in English and metric. Pivoting grip for better accuracy. No click style unless your eyesight is poor, or you otherwise have difficulty reading a torque wrench. If it is worth getting out the torque wrench it is worth getting the desired torque IMO.
jcl is offline   Reply With Quote
Old 12-15-2019, 11:27 AM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Harbor Freight is what I settled on. I keep it in my truck (tow vehicle) at all times because it also checks torque when I rotate those tires.
https://www.harborfreight.com/12-in-...nch-63882.html
Setting to "0" when not in use will keep it accurate.
Don't use it for loosening or tightening. It's job is to check tightness that is done with a different wrench.
I have a beam type too, but after decades of use it does not return to the "0" mark on the indicator.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 12-18-2019, 09:04 PM   #15
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by too tall View Post
precision instruments 1/2" 40-250 ft-lbs. Split-beam torque wrench c3fr250f
i've had one of the above for two years. You do not have to return the wrench to zero.
x 2
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 12-18-2019, 09:06 PM   #16
2016 16' Sport
Miami , Florida
Thanks guys.
Old 12-19-2019, 12:19 AM   #17
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
This is the one. Precision instruments makes this exact wrench for Snap-On. Snap-On sells it for five or six hundred bucks. You can get exactly the same thing for about $150.00 on Amazon from Precision instruments. It comes calibrated, and does not need to be reset to zero every time. I learned about this wrench from School Bus diesel mechanics in Beaverton OR. I’ve had mine for almost two years now. It’s a great wrench.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 12-19-2019, 07:11 AM   #18
Beverly Hills , California
I stopped using Crafstman torque wrenches. Had one go bad while sitting. Same thing for the second. Both of them were mostly used for lug nuts during tire rotation and un-wound when not in use. Helping the decision to stop was that torque wrenches do not fall in Craftsman's unlimited warranty category.
I forget the replacement make, but I went to the 'jungle' and got a more expensive wrench than the Craftsman and it is lasting longer than either of its predecessors.
JayTheCPA is offline   Reply With Quote
Old 12-19-2019, 10:00 AM   #19
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Napa...snap on..
Old 12-19-2019, 08:48 PM   #20
SandKSmith's Avatar
Scottsdale , Arizona
I’ve got a Craftsman that’s nearly 50 years old. Had it calibrated locally (Phoenix $35) and all is well. I always put it back tp “0” when finished.
Steve
SandKSmith is offline   Reply With Quote
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 07:15 PM
Torque wrench recommendation needed Papa smurf General Repair Forum 101 03-20-2016 10:39 AM
Torque Wrench by Husky Devoman General Repair Forum 3 01-10-2016 07:51 PM
Torque Wrench..Which one to use. jomondnv General Repair Forum 38 03-19-2013 07:49 AM
$28.99 for a torque wrench... did I was my $ Kistler Our Community 3 03-11-2004 07:27 PM
