Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-13-2009, 07:02 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Took it out this weekend after sitting for the winter
I took my 73 Overlander camping at a state park this weekend. Had some frustrating kinks to work out. Little things that were caused by not thinking ahead of time. I have been slowly changing out the Questia plumbing fittings with Shark bites. This has been a slow process because of the cost. Questia fittings are terrible for plumbing. I had to fix three different leaks which all were located at the questia fittings. The other problems were grease ants. They moved in over the winter. I had to bug bomb the trailer when I got home. They were a problem and hopefully t hey are gone. The last thing was the airconditioner. It worked great last summer but it was not cooling this weekend. I have to fix the airconditioner and leak. Other wise everything else worked great. I did pick up a propane smell which means I need to get my lines checked.
Lothlorian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 04-13-2009, 09:03 PM   #2
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Sounds like you worked out most of the bugs. I'm going to try to get with you next week. Somehow, I have 5 weeks without the pager from work starting next Monday. Maybe we can get together and compare notes on a few things. Call me when you get a minute.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
'65 overlander been sitting dreadydreame 1965 - 1969 Overlander 10 01-01-2009 06:47 PM
Airstream sitting for 15 years... Mrcrowley Waste Systems, Tanks & Totes 17 08-18-2008 01:46 PM
Furnace sitting on plywood Sweski Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-23-2007 06:33 PM
50-something sitting on axles on ground HELP?! true1977 Vintage Kin 8 07-28-2005 12:28 PM
